[FOR SALE] MOPAR DOOR HINGE RESTORATION SERVICE
MoparLeo
NRA BENEFACTOR LEVEL LIFE MEMBER
Moreno Valley, Cal. So. Cal.
FOR SALE - DOOR HINGE RESTORATIONS
As long as they are not broken/damaged, modified or extremely worn I can do those as well. Same prices as the others.
MoparLeo, I know in the past you did NOT offer a rebuild service for early A bodies (mines a '65). Am I to understand you now rebuild the '65 hinges?
The problem with doing the early A-body was getting proper springs made for them. I have been able to modify the 67 and up spring and use the 62-65 spring roller.
Spring time is here !!! Car shows and cruises are coming back. People are going back to work.
Get your door hinges remanufactured now ! Things are picking up and we need to get our cars back on the road or into paint.
Member discounts . Email any questions. Thank you for your business. Top rated for quality and service.
I hope everyone had a safe and fun 4th.
Country is partly open, the car shows are happening again. Good times are ahead !!
Get your door hinges done so you can get that paint and body work done correctly. Set up your gaps and get her painted. Or door won't stay open ? Makes noises ?
We can cure that. Member discount pricing, quick turn around service.
PM me for more info. Thanks. Leo
  • 2021 MEMBER DISCOUNT HINGE PRICES.pdf
  • A-B-HINGE-INSTALL.pdf
Can supply a few sets of Cores, if desired / needed. Have two pairs of '67 - '76 A front door hinges, and have access to 1 1/2 sets of '63 - '66 A front door hinges. Bolts would be included.
Dave S
southern New Mexico
Really only need E-body cores.
I could use some 67-76 A-body lowers with no cracks, rust pitting or excessively worn lower pivot pin holes as they are the same as the 67=70 B-body hinge.
Bolts, etc... just go in the scrap bucket.
Happy 2022 !!
Pricing going up this month. Our custom parts supplier has retired and sold his business, so that means higher parts pricing. Get your orders in while current parts inventories last.
  • 2021-MEMBER-PRICE-SHEET (3) (1).pdf
  • DOOR-HINGE-PROCEDURE (1).pdf
It is always preferred to use your originals unless they are damaged and beyond repair.
Here is the current price sheet and pictures of common A-body problems.
Thanks
Leo
  • DOOR-HINGE-REBUILD-PROCEDURE 2022.pdf
  • 2022 MEMBER HINGE PRICE LIST.pdf
