- Joined
- Apr 16, 2009
- Messages
- 4,347
- Reaction score
- 6,204
Can you still buy paint stripper with methylene chloride and if so, where at?
Thanks in advance FABO.
How does you're blast cabinet work? Mine was a pos until I did the metering valve mod. They should come with one and not the crap siphon set-up.I am just trying to strip an intake manifold that has two coats of primer over a coat of black over a coat of orange.
It is a Victor 340 so worth messing with but it is taking forever to get anywhere in my blast cabinet.
Its a mess.
Not sure what they were thinking?
I have blasted about 10 manifolds with no problem with it but I am interested in what you have done to yours.How does you're blast cabinet work? Mine was a pos until I did the metering valve mod. They should come with one and not the crap siphon set-up.
I used to sandblast locomotives with a heavy duty sandblasting setup. The locomotives that had epoxy type paint and some even had a clear coat back in the '80s were extremely hard to remove. The ones that had a straight enamel paint, well it practically flew off them. My point is, the stronger the paint the harder it is to remove. You just have to have patience.I am just trying to strip an intake manifold that has two coats of primer over a coat of black over a coat of orange.
Its a mess.
Its a mess.
This is the one I have been looking at.I get Kleen Strip paint stripper at ace hardware, and it has worked on everything really well.
You got a way better cabinet than mine. It might already have a metering valve. Look the mod up on YouTube.[QUOTE="dowboy1970, post: 1974623487, member: 9844]…
This is the one I have,
24" x 48" Sandblast Cabinet
What would you suggest for a small quanity?Its still available with methylene chloride. Just gotta go through the hoops. Funny thing, you can go to amazon and buy straight methylene chloride by the gallons.
You can search to a website who sells it. You need to have a business license. I have the info somewhere but have not needed it as I have a decent stockpile of the illiterate people killing product.What would you suggest for a small quanity?
