Rodified #4 Cylinder
Daves69
WestOfChi
This is a '68 440 Hp block that has received modification to #4 cylinder by a wayward rod years ago. Approximately 1/2" chunk is bit out. Across the lifter alley #3 has just a small nick. Other than that, nothing else evident w/o throwing bucks at it.
For those in the know, how much is too much on #4 cylinder?
That's a tough one and nobody's gonna really be able to accurately answer that because each block will be different due to core shift. The best thing to do is take it in and have it pressure tested. If it passes, what I would do then is have it sonic tested, particularly that cylinder in that area. That will give you a good indication of "where" the water jacket starts.
If your running a stock skirt piston, go for it. The stroker pancake pistons will lower the ring pack. yooull have to slide a piston down and see where the oil rings are in relation to that chunk. Doesn't look like any piston rocking issue as it looks to be about 3/4 inch long? Farmer John would run it.
If rest of block is good, could be sleeved.
Yeah but if that broken spot is REALLY THIN to the bottom of the water jacket it can still start leakin. Even with a sleeve. He needs to find out how thick that is in relation to the bottom of the water jacket.
The oil rings will never ever make it down that far. He's good there.
Sleeve it and go. The block is solid down there. You don’t need to run the sleeve out the bottom. That’s wrong. Leave a .500 step at the bottom.
It will run forever if it’s done right.
Thanks all for the responses. So that you all know, this is not a hot project for me as it's a third block I have laying around taking up space. I'm am trying to disposition known damage to determine whether or not it is even worth keeping or offering it to others.
....He needs to find out how thick that is in relation to the bottom of the water jacket.
I believe it's a standard bore block now. It's what I was told when I acquired it. Taking .015" out per side makes it thinner yet. Any idea if an ultrasonic thickness meter works on cast?
Seriously would consider the option depending on cost.
.....Farmer John would run it.
:rofl:
Lol, I haven't planted in years! When I did, it wasn't pretty. Defiantly not a green thumb here. Then too, I could take John's approach.
...... Leave a .500 step at the bottom.
So if I understand ya', end the sleeve bottom at the top of the breakout? What's typical cost for a single installed these days?
:rofl:
Sure, I've sonic tested plenty of cast iron blocks myself. ...and I do believe YR is correct that it is solid down that far......I am merely pointing out that it would be best to verify that and you can do that with a sonic tester. It would be terrible to build a whole engine using that block and find out later it sprang a leak. That's why I said a sleeve will do no good "for that" but of course it would repair the integrity of the broken piece. ......although if it's solid down there.....and I believe it is, it doesn't really need a sleeve. It's just best to verify, as this hobby "ain't cheap".
:rofl:
My bad. I thought there was other damage above that.
I’d take a grinder and purdy that notch up (as long as it’s been Mag’d and it’s not fractured) and send it. No need to even sleeve that.
