Unconventional Well-Known Member Joined Apr 17, 2017 Messages 26,801 Reaction score 40,473 Location Santa Maria, Ca. Jul 21, 2020 #1 Will an 833 or similar 4 speed fit in the same tunnel that a manual 3 speed once resided in?
Professor Fate Push the button, Max... Joined Jan 13, 2020 Messages 6,637 Reaction score 11,645 Location Wisconsin Jul 21, 2020 #2 If it was a floor shift 3 speed, then yes. If it was a column shift, then you will have to cut the driver's side of the tunnel and add the floor shift hump in order to fit an 833. Other 4/5 speeds will require additional mods to fit.
