Unported head quickness?
Wait a minute, wait a minute. Cnc ‘d heads are ported. Exstreamly ported.
And that's why I asked but I think the purpose of this thread was to show what kind of out of the box performance people get and with what combo. My junk is most definitely out of the box. lol
They don't sell a tf sbm head without CNC which comes out of a box lol.
Like you just said lol
While 100% true, they are a OOTB head. Before TF, this wasn’t possible. The initial spirt of the thread, the idea of a stock port and as fast as you have been with it. Save money on porting, to fast! LOL
Prior to TF, ProMaxx would get the chink head and CNC port it, resell it. That isn’t exactly the same IMO as the TF head because that’s the only way you get the TF head.
Thanks!
Thanks!
Guess I should have added “no chinks were harmed in the making of this pass” to my post…. lol
OK crew. Another idea I had. This is, kind of like a , "Build it on the cheap" thread. As the title states, unported heads save a lot of money.
Big block, small block, /6ers as well, factory iron heads preferred, aftermarket heads welcomed. Though aftermarket heads are a little bit of self thread defeating purchase, I guess, if ya ain't got any heads, you'll need to get some, so, they might as well be added in. :thumbrig:
"How fast have you gone with "UNported heads?"
Not your buddy, not your neighbor, not your Ma'am, well, maybe...LOL
Seriously, list the combo, what you did to the engine, and the rest of the goodies in/on the car that get you there. Dead stock engine? Let'em know. Rebuilt, tell us the parts! Stock carb'd? Let us know. Exhaust manifolds, state it! Give up the goods and help a fellow MoPar guy pound some pavement or budding racer get going.
Engine and parts;
Trans/converter
Rear gear and tire size
Suspension
Light weight parts
(or missing parts)
Cars weight
E.T. / MPH
Engine and parts;
Trans/converter
Suspension
Light weight parts
(or missing parts)
Cars weight
E.T. / MPH
1970 Dodge Dart.All steel weight #3480 with driver.1974 360 engine pulled from Dodge van.
Cylinder heads are J heads 1.88 valves with a basic valve job.still using the original valves that were installed at the factory.factory replacement 340 springs and factory non adjustable rockers
Short block is .030 over with KB 107 flat tops
9.87 compression factory rods reconditioned with ARP bolts factory crank cut .010/.010 and balanced.727 trans. rev manual valve body
8-3/4 with 3.91 gears.
Cam is Mopar purple shaft .509/292.Intake is Edelbrock TM-5 Carburetor is Holley 750 Double Pumper Fuel pump is Holley Blue
Super stock springs 90/10 front shocks
Car runs 11.79@113 on 26x8 slicks
11.99@111 on 28x10.5
stock 5.7 hemi with modman intake. Enderle bird catcher injector and a hughes aftermarket cam and lifters. running alcohol in my 3000lb 67 barracuda. ran 10.71
How can it be a stock 5.7 if you put a Hugh’s cam, enderle injection, and on alcohol. You guys don’t even understand STOCK. Lol
Could you round out the rest? Trans, stall, rear gear and tire size and type? Any suspension and body mods as well please.
Cam specs would be awesome.
(The thread(s) of this section are though up with the hopes people would share all the information to copy (the most nearest form of flattery) and take the mystery out of going fast. Thanks.)
It’s unported head quickness. He took a stock 5.7 and then added in the mods done. AKA, Stock other than….
No big deal here.
No big deal here.
I’m trying to prevent him from looking bad at the local cruise when he starts telling some old timer sipping on an umbrella drink that his cars stock then start telling him about the mods he did. Lol
