junkyardhero
- Joined
- Jan 23, 2005
- Messages
- 3,101
- Reaction score
- 4,867
that's what break in oil is for, right guys?It’s just breaking in! Well, maybe just breaking…
guys? hey! where are you going? come back!
I would also endorse the Comp DEH275 here. IF you can find one. A better idea would be to let Oregon grind whatever their closest is.The old comp High Energy 268 is also another good choice here. Or even a regrind on an old 360 cam core and lifters. An Oregon 1369 ground onto 108 LSA is as good as it can get here. It’s doable because most stock 360 cores are ground close to a 109 to start with.
Hydraulic Camshaft Specifications
Do you have a part # for those 5.2 magnum pistons? I asking because the last time I looked those up they were the same thing as the LA pistons.Someone asked how you get to 9.2 compression, .030 overbore, magnum heads, and you can use 318 magnum pistons that have a taller compression height in a LA motor they work fine, as 5.2 and LA engines have basically the same rod You would want to re-balance but that's always a good idea when changing pistons anyway. They are not as tall as the KB's but will get you a nice boost in compression for replacement piston prices.
The stroke and the rods didn't change dimensions but the heads did so the compression height of the pistons had to change.I've often wondered what exactly the difference was in the 67-69 9.2:1 318 and the 84-ish to 91 9.2:1 318 to differentiate them from the 8.8:1 318's from 1970 to 1983.
The piston part numbers are different, and the heads are different, but I've never been able to compile exactly what portion is attributable to what part.
probably compression height of the pistons and open chamber headsI've often wondered what exactly the difference was in the 67-69 9.2:1 318 and the 84-ish to 91 9.2:1 318 to differentiate them from the 8.8:1 318's from 1970 to 1983.
More Information for SEALED POWER H814CP they're still .060 in the hole based on compression heightDo you have a part # for those 5.2 magnum pistons? I asking because the last time I looked those up they were the same thing as the LA pistons.
No valve reliefs, would that cause piston to valve clearance problems?More Information for SEALED POWER H814CP they're still .060 in the hole based on compression height
Those are fairly obvious observations.
If you use 1967 pistons (and change nothing else) on an 8.8 engine, what is the new compression ratio?
If you use 1986 pistons (and change nothing else) on an 8.8 engine, what is the new compression ratio?
If you use 5.2 Magnum pistons (and change nothing else) on an 8.8 engine, what is the new compression ratio?
If you use 1967 (920) heads (and change nothing else) on an 8.8 engine, what is the new compression ratio?
If you use "302" heads (and change nothing else) on an 8.8 engine, what is the new compression ratio?
If you use Magnum heads (and change nothing else) on an 8.8 engine, what is the new compression ratio?
...and the several other potential combinations.
What do the heads flow (cfm) that would give you something to go on for cam selection.
Lift (or max lift) has almost nothing to do with P to V. It’s not how far the valve opens, it’s when and how long it opens. Duration has the biggest impact on P to V clearance.That depends on a slew of things. How far the piston is down the hole, how big the valves are & how much lift the cam has, or actually the actual valve lift. Head gaskets selection also has a play on this
Don't forget head gaskets. They went from .020" steel shim gaskets to the much thicker composite head gaskets too. So there's some more difference.The stroke and the rods didn't change dimensions but the heads did so the compression height of the pistons had to change.
@Dan the man watch this video
Can you explain why it's a bad idea? Other than your opinion? As long as the valve train geometry is correct with the correct length pushrod, it hurts nothing. So from an actual engineering standpoint, please tell us why it's not a good idea.Re-grinding a stock cam to get more lift will leave the lobe physically much smaller..... You may need longer prods. Not the best solution.
All my old Chilton manuals said the 70s and earlier 80s 318s were 8.6:1 and 360s were "advertised" as 8.2- 8.4 but then in the 80s some of the 360s were advertised as actually being below 8:1, the heavy duty ones in 1 ton trucks and such being listed amongst the lowest.I've often wondered what exactly the difference was in the 67-69 9.2:1 318 and the 84-ish to 91 9.2:1 318 to differentiate them from the 8.8:1 318's from 1970 to 1983.
The Early Hemis from 53-59 were all advertised at 7.5:1 if they were in trucks.All my old Chilton manuals said the 70s and earlier 80s 318s were 8.6:1 and 360s were "advertised" as 8.2- 8.4 but then in the 80s some of the 360s were advertised as actually being below 8:1, the heavy duty ones in 1 ton trucks and such being listed amongst the lowest.
I wonder then if the ones advertised as below 8:1 were really in the low 7s.... My experience with engines from that era is as built they are all less than "advertised" CR.... Pitiful. No wonder some of these engines were such wheezing gas sucking slugs..... Not just talking Mopar either ...
I would not be surprised. Why would you want higher? If you had a Dodge D500 dump truck fully loaded with dirt and a 354 Power Giant under the hood, you sure as heck wouldn't want 10:1.And they probably were lower than that. I’ve pulled several of the early hemi’s apart and I checked one. It was 6.7:1.
