Yet another 1968 Plymouth Barracuda B029 Hurst Hemi Super Stock
Oklacarcollecto
Life is an experiment
North Central Oklahoma
This is a 1968 B029 original Hurst Hemi Super stock Plymouth Barracuda, one of 55 produced. It has been documented by Dell Jones to be the "last car" built as a factory race car in 1968. Raced by Eddie Smith, known as the "West Virginia Hemi" and known as the best appearing and one of the fastest cars at the track. This car is immaculate in every respect. The engine was rebuilt by Jim Hale, a well known drag racer for the past 40 years and still campaigning Hemi Super Stock cars today. This car has the best of everything and has competed in several Super Stock Hemi shootouts at NHRA Nationals, the Dutch Classic and the Sport Nationals. This car has an NHRA certified chassis, automatic racing transmission, race convertor, Precision Performance shifter, 9" Ford rear end, Lamb brakes, Mark Williams axles, Weld racing wheels, Magnaflow fuel pump and Autometer gauges. This car is perfect in every respect, it is authentic and one of the nicest cars in the country.
http://www.leakecar.com/index.cfm?id=208&auc_code=DALFAL11&lot=486
Awesome car. interesting dash. Large pods look a bit like speakers.
Just wondering how much the original B029 M8299135 Hemi car title is worth to a car that Mike Smith drove that was originally Dale Barkers? Was being worked on by one of the ex Ram Chargers and disappeared in Michigain.
After being publicly posted, and I'm sure documented, I'd say nothing now..
Nice 68. Boy would love to have found one of those cheap in my days..
Grant
Here is some info I have found on the SS cars.
The Introduction of the S/S Hemi Barracudas created controversy in the stock ranks, where the little guy now found himself pitted against nation record holders in factory-built race cars. On February 20, 1968, Chrysler-Plymouth general sales manager R.D. McLaughlin outlined for dealers- and racers -what they could order. The following is a reprint of his letter in its entirety.
CHRYSLER ANNOUNCEMENT LETTER
1968 SUPER STOCK BARRACUDA
February 20, 1968
TO: All Plymouth Dealers
Subject: 1968 Hemi Barracuda Super Stock
The Chrysler-Plymouth Division offers for the 1968 models a 426 Hemi-Powered Barracuda Fastback for use in supervised acceleration trials. These cars will weigh approximately 3,000 pounds and have been designed to meet the 1968 specifications of the major sanctioning drag strip organizations.
The Hemi-Powered Barracudas will be available through production is limited quantities in March. To order this vehicle, use the Barracuda Order Form and specify Body Code BO29 and Transmission Code, either 4 Speed Manual, Code 393, or Automatic, Code 395. No other specifications are necessary.
Description of Components
426 cu. In. 8-cylinder engine with dual 4-barrel carburetors- 12.5 to 1 compression ratio.
Cross Ram Intake manifold.
1 11/16" x 1 11/16" Holley carburetors.
Competition Hooker headers, exhaust pipes, and mufflers.
High capacity oil pump.
Roller timing chain (reduced timing chain stretch for more consistent engine performance).
Mechanical valve gear.
Dual breaker distributor.
Transistor ignition.
Metal core type ignition wires.
Unsilenced air cleaners.
Deep groove fan drive pulleys.
Heavy duty radiator.
Aluminum seven-blade fan equipped with Viscous drive.
Special offset 15" rear wheels.
Chrysler-built 8 ¾" large stem pinion gear set, and heavy-duty axle
shafts with automatic transmission (4.86 axle ration).
Dana-built 9 ¾" heavy-duty axle with manual transmission (4.88 axle ration).
Sure-Grip differential.
135 Amp. Hr. battery (located in rear compartment).
Heavy-duty high control rear suspension.
Front disc brakes 41/2" Bolt Circle.
Fiberglass front fenders.
Fiberglass hood with scoop.
Light weight steel doors.
\Light weight front bumper.
Light weight side window glass.
High capacity fuel lines.
Business coupe interior (2 bucket seats - no rear seat).
For Manual Transmission Only
Special heavy-duty 10 ½" clutch and flywheel.
Safety steel clutch housing.
Competition "Slick Shift" 4-speed transmission.
Hurst remote mounted floor-shift unit with reverse lockout.
For Automatic Transmission Only
High stall speed torque converter (large drive lugs and 7/16" diameter attaching screws).
Heavy-duty manual shift TorqueFlite transmission.
Hurst floor-mounted shift unit.
Please Note: The following items are deleted on this body type:
Heater, Body Sealer and Sound Deadeners, Silence Pads, Outside Mirrors, Right Side Seat Belt and Body Color Paint.
NO OPTIONAL EQUIPMENT OF ANY KIND CAN BE ORDERED
The policy of Chrysler Corporation is one of continual improvement in design and manufacture, wherever possible, to insure a still finer car. Hence, specifications, equipment and prices are subject to change without notice.
These vehicles are intended to use in supervised acceleration trials and other competitive events, therefore, they will be sold without warrant. Special stickers will be provided for plant installation (attached to left "A" post) which will read as follows: "This vehicle was not manufactured for use on public streets, roads or highways and does not conform to Motor Vehicle Safety Standards.
All customer orders must be accompanied by a signed disclaimer (sample attached) indicating that the purchaser understands that this vehicle is sold without warranty and does not conform to Federal Vehicle Safety Standards.
Any prospective customer who desires to purchase one of these maximum performance vehicles should be made aware of the following characteristics which make them unsuitable for general use.
A high idle speed is required to insure adequate lubrication, minimize roughness, and to keep the engine from stalling.
The modified intake manifold causes a rich surging condition, misfiring and unstable engine operation in cold weather, which makes ordinary street driving extremely difficult and it is not recommended for this use.
all LO23 and BO29 cars were built with the same specs ,at the same time . at the same hurst facility
the introduction of the S/S Hemi Barracudas created controversy in the stock ranks, where the little guy now found himself pitted against nation record holders in factory-built race cars. On February 20, 1968, Chrysler-Plymouth general sales manager R.D. McLaughlin outlined for dealers- and racers -what they could order. The following is a reprint of his letter in its entirety.
February 20, 1968
Please Note:
Higher than normal oil consumption will be encountered because of increased lubrication to the
valve train and cylinder walls.
The carburetors are calibrated for maximum power and a high numerical axle ration is used for
acceleration. As a result, the gas mileage is considerably less than for a conventional car.
Engine noise would be objectionable due to increased piston clearance and mechanical valve
tappet clearance.
The ignition system is designed for optimum engine output and must be kept in top condition. This
makes it necessary to inspect, adjust and replace the spark plugs and ignition points more
frequently than would be necessary on a standard engine.
On car equipped with automatic transmission, band adjustment must be made frequently.
Due to performance characteristics, maintenance and operating expense will be high since premium
fuel is required and frequent oil changes are a MUST.
Does not conform to Motor Vehicle Safety Standards.
Warranty and Policy Coverage
Any customer purchasing this model vehicle should be advised that due to the expected use, the vehicle is sold "as is" and the 24 month or 24,000 mile vehicle warranty coverage, the 5 year or 50,000 mile Power Train Warranty coverage, or any other warranty coverage (including, but not limited to the implied warranties of fitness for purpose intended or merchantability) will not apply to the vehicle. The manufacturer assumes no responsibility for the manner in which such vehicles operate.
Any repairs or adjustments which you believe warranty factory participation should be brought to the attention of your Regional Service Office where such requests will be handled on individual merits.
Attached is a form letter (to be prepared on your letterhead) which should be thoroughly understood and signed by each prospective purchaser and attached to your order for each Hemi Barracuda Super Stock. The purpose of the letter is to explain the normal operation characteristics of these vehicles and clarify that the warranty coverage’s do not apply. Be sure a letter in this form, signed by your customer, is included with your order so there will be no delay.
1968 Hemi Barracuda
It was inevitable that Chrysler would build the Hemi Barracuda. For the past four years, drag racers had been gutting Barracudas and dropping in 392 and 426 Elephant Engines. Since Chrysler had enjoyed tremendous success on the dragstrips in Super Stock and Unlimited Fuel since 1963, the decision to continue that domination by building a factory super stocker (with some assistance from Hurst) was a natural.
The S/S Hemi Barracuda was assembled by Chrysler as a package and then shipped to Hurst. Although the number varies from source to source, at least fifty and possibly as many as seventy-five Barracudas were shipped to Hurst’s facility in Detroit. The conversions were coordinated by Dick Maxwell at Chrysler and Richard Chrysler at Hurst. As delivered to the dealers, the cars had fiberglass hoods and fenders, while the front bumper and doors were light-gauge steel. The interiors were gutted and Bostrom driver seats installed.
To squeeze the mighty Elephant into the Barracuda’s tight engine bay, some modifications had to be made under the hood. The battery was moved to the trunk, and the right shock tower was moved, as was the master cylinder. Hurst also installed custom headers, shift linkages for four-speed cars and special rear-axle assemblies. Off the transport trailer the cars were delivered on street tires. All that was needed to make the car competitive was slicks, a deeper oil pan (a small pan was installed for shipping), camshaft and valvetrain.
The S/S Hemi Barracudas were delivered to racers in early May, in time to qualify for the NHRA Spring Nationals. Ronnie Sox was one of the first to get a Hemi Barracuda on the strip and turned mid 10s right out of the box
Info on SS continued
tappet clearance.
1968 Hemi Barracuda
valvetrain.
Ma Snart
73AbodEE
Guess you and me are on the same wave length today!!!
Most of the info I posted I got from you!!!
Ma Snart
wow man no wonder i couldnt post, you were already doing it lol you beat me to it Ma !!! thats alright, we will leave it all up so there is no question lmao
Pretty cool coincidence, Heh?
MA Snart
some more
more
That is a nice cut-up racecar, for one of the 70 produced...;^) Mine needs a little work, but will be fun when done... The automatics were 8-3/4's and the 4-speed's Dana 60's. There were 150 total built, 70 Barracuda's (all fastbacks) and 80 Dart hybrids (mostly GTS but parts of Dart 270). They all had Bostrom seats from A-100 vans and fiberglass front caps painted black primer while the rest of the car was grey primer on the outside and everything else like floors/jambs/trunk/engine compartment were gloss black. Anyone who wants to know more about these cars needs to pick-up Jim Schild's Authenticity Guide 1968 Dart & Barracuda Hemi Super Stock.
