Was wanting to see what you offer for a 1968 Barracuda 440 4 speed its wanting to heat up in traffic.
Any suggestions would be great!
Thanks kenny
Thanks kenny
Thanks kenny
Sad , Very very Sad. I would like some info on that also !
Thanks kenny
I order my custom radiators from US Radiator. Especially with the smaller 22" opening. They have several different build options they can use depending on your specific application.
As mentioned above, the radiator is just one link in the chain of good cooling. You will need a proper fan, thermal clutch, water pulley set-up and shroud to get the greatest cumulative cooling effect.
