I picked up an Autometer Fuel Bridge over the weekend -
FUEL BRIDGE, FUEL SIGNAL ADAPTER FOR AUTOMETER GAUGES
I bought it for 2 reasons; 1. because I drove past the Summit store in Sparks and had to buy something and B. because I liked the idea of a low fuel warning light (someday).
My plan is to siphon my tank using the pickup so I know where empty truly is, then map the readings from there to full while filling it up. Then I can come up with resistance values for E (+2 gallons), 1/4, 1/2, 3/4 and full. This should give me an accurate gauge reading that matches my tank.
Last step is figuring out a way to feed the adapter the right numbers so I don't have to pull the sender. First thought is dig out the sender I replaced with this piece of junk and use it. Don't feel like creating a science project of resistors to set the values like above. If the values match Mike's creation above, might take him up on his offer of a loan. Time will tell.
