Check it, 318's were just bread n butter engines, I have never seen one with much from the factory, especially an 1985.
will doCheck it, 318's were just bread n butter engines, I have never seen one with much from the factory, especially an 1985.
Well.. that makes me sad... went and measured, piston is .050 in the hole and with a .080 head gasket that makes 8.62:1.. not great.. but it's what i got.. this is gonna suck more than i expectedCheck it, 318's were just bread n butter engines, I have never seen one with much from the factory, especially an 1985.
Ahhh thanks much! 9.6 sounds much better than 8.6Mr. Gasket Head Gaskets 1121G are .028 thick.
They can be used on an untouched deck.
will take a lookComp has a desktop dyno that free, you can plug in any of there cams, and it gives a pretty accurate read-out.
How she work ? performance and driveability wise, what gears and stall?This mean mama jama is in a stock piston, 900 cfm TQ topped 318 magnum. Stock stroke
Yes, I like the looks of that one.How she work ? performance and driveability wise, what gears and stall?
what gears/converter? just curious.. that 106 is interesting.. i went 109This mean mama jama is in a stock piston, 900 cfm TQ topped 318 magnum. Stock stroke
Was just wondering, my cam is .525 with 225/232@50 on 109... will have to use a stock coverter though til i get parts to convert to 24 spline on the trans@toolmanmike @Icetech @273
4.10 gears, 3500 stall in a 727. Performance is great. Engine was originally built for high banked dirt track figure 8 racing which is where the cam design cam in... Jim at Racer Brown made the profile to have low end torque to help the car come out of the corners and deal with the mandatory yield/stop rule. Made for 6,500 rpm but to have low end grunt thus the low duration @ 050 and the 106 lsa. Stock pistons flipped backwards (lets avoid that debate) with hoke ported heads, Chinagap intake and modified Thermoquad. Thumps really well too
I understand that. Jim took a long time thinking out the specs for it since it was an unusual request.Was just wondering, my cam is .525 with 225/232@50 on 109... will have to use a stock coverter though til i get parts to convert to 24 spline on the trans![]()
yeah, i wanted 108 but to keep the duration down cause of crap gears (now i have 4.57s but i don't think i will run them, it's too much) and got what i could off the shelf.. is that a roller?I understand that. Jim took a long time thinking out the specs for it since it was an unusual request.
Yep. Hydraulic rolleryeah, i wanted 108 but to keep the duration down cause of crap gears (now i have 4.57s but i don't think i will run them, it's too much) and got what i could off the shelf.. is that a roller?
The 318 it went inyeah, i wanted 108 but to keep the duration down cause of crap gears (now i have 4.57s but i don't think i will run them, it's too much) and got what i could off the shelf.. is that a roller?
It's a modified Stromberg WWC 2 barrel. Uses Holley jets and is about 500 cfm. My grandpa swore by them when he raced his hobby stock 360. The figure 8 class is basically anything-goes as long as you use factory style exhaust manifolds. No headers. That's the only rule.What carburetor is this? I assume a spec class with a 2-barrel requirement.
