TT5.9mag
Two atmospheres are better than one
It’s the rings and the factory fuel injection that’s responsible.Thin low tension rings and hypereutectic pistons seem to do that in anything
WellI was going to say that but I didn't want to start a **** storm like the one over the actual 340 cam specs. LolI’d argue that the stock mag heads are better than any stock LA head.
They are better machined from the factory, however the cylinder walls on most I've machined couldn't go over .030 which I think isn't great but wear overall is better to start with.I’m not a machinist but I’ve always heard the mag blocks are better quality.
Has production machining equipment not gotten better and/or more accurate in the last 30 years? Serious question because In the industry I’m in, the cnc machines are light years better than they were even 10-15 years ago. I have 3 multi million dollar cnc machines (for structural steel) that are 8 years old and damn near obsolete at this point.
We are talking factory pick up truck engine here. "Factory" was mentioned in the first post. It's what this thread is about. Yes, wrong forum. I will move it.8
Thank you for posting your firsthand knowledge on the 30 overThey are better machined from the factory, however the cylinder walls on most I've machined couldn't go over .030 which I think isn't great but wear overall is better to start with.
That's just the few I've done. Any will need to be checked because some will go bigger.Thank you for posting your firsthand knowledge on the 30 over
I'd also add to the machining process, the machinist himself is where quality comes from, not the machine itself. I use machines from a generation before mine. I set the clearances, make the crosshatch. Not the machine, I'm sure a CNC machine would do better and faster but it still takes the dude to plug in those numbers.It’s the rings and the factory fuel injection that’s responsible.
Just put a 4bbl and headers on an otherwise stock 5.9 and you have 300 hp. 5.2 would be only a tad less.Depends what you think a factory 340 makes, a stock 5.9l magnum dynos 280 hp bet the 5.2l ain't far behind so probably similar but way better under the curve at least.
I’ll add a cam and springs to your list as well. That really wakes up a 5.9.Just put a 4bbl and headers on an otherwise stock 5.9 and you have 300 hp. 5.2 would be only a tad less.
I believe the question I was answering was,Short Block is all I agree with.
The efi system is not that great.
The camshaft is weak weeny
The cylinder heads don't flow worth a crap and can't be ported to support real HP 550 or greater.
Chamber design okay, chamber actually junk they all crack between the seats.
They are untunable without someone else building a tune for you.
If you wanted to do a real cam swap there is 1 or 2 very expensive options for adjustable rockers.
I mean @ Brooks James posted this in the racers forum and he's talking about stock slow stuff.
There's a magnum/ small block spot just for a thread.
My reply was based on the thread it was originally and incorrectly on.I believe the question I was answering was,
“What part of the magnum was superior stock???”
“The efi system is not that great.”
Somewhat true but, you get a block that has good cylinders
“The camshaft is weak weeny”
True, but did most LA come stock with much better, and provisions in the M block make roller lifters easier come cam swap time, you know you’re gonna swap cams anyway.
“The cylinder heads don't flow worth a crap and can't be ported to support real HP 550 or greater.”
Which are we talking about stock or not, I forget, but the statement did say stock.
“Chamber design okay, chamber actually junk they all crack between the seats.”
True,
“They are untunable without someone else building a tune for you.”
True, because of the EFI I suppose, but you did say stock, so I would say that there are more EFI engines running pretty good with 100K+. Back in the day someone was some kind of god if they had a car with over 100K, and they certainly didn’t have cylinders with hone marks if they did.
I’d bet “production” machining is no longer a guy plugging in numbers. As the machines get better they get more accurate, and need less involvement from a guy.I'd also add to the machining process, the machinist himself is where quality comes from, not the machine itself. I use machines from a generation before mine. I set the clearances, make the crosshatch. Not the machine, I'm sure a CNC machine would do better and faster but it still takes the dude to plug in those numbers.
I guess I'm trying to say it's takes someone wanting to do it correctly on any machine
I'm not sure anyone said it can't be tuned.The myth that the stock ecu cannot be tuned needs to die. The JTEC ecu can be tuned multiple ways. And most notably now is HP tuners.
Anybody who can turn a computer on and make it work is a wizard to me lolIt doesn’t really take a wizard. It takes some effort though. About the same amount as most people won’t invest in tuning a carburetor.
Yeah you're probably right. I'm sure you areI’d bet “production” machining is no longer a guy plugging in numbers. As the machines get better they get more accurate, and need less involvement from a guy.
Anyone remember the thread where some dude wanted to bore and hone a block with a mag drill?
Just not a bone stock factory delivered magnumI think to answer the OP's question .... yes, the magnums can spin to 6500 with stock rockers
LA vs Magnum =Junk and Junkyard dog fight Gggrrrrrrrrr
Magnums!!
Interesting. I have not had similar results. My LA stuff has always liked 36-37 degrees for max power. My magnum likes 32-33. Is that enough of a difference to quantify “more efficient”, hell who knows. But it is consistent, at least in my experience.The chambers are not more “efficient”. The magnum uses the same timing or within a degree or two.
