65 Dart Wagon Conversion to a Sedan Delivery
I found a couple well used (dented) dust covers. I’d like to find some new ones but at $13 or more for new ones each, might have to let the Magnum 500s hide the covers
I’m getting ready to install the rotors and front brakes - NOS Calipers and hold down hardware I bought from @slantsixdan, new F Body brake hoses (the calipers will be mounted to the rear so the longer F Body hoses are required), and new Wagner semi metallic brake shoes through Amazon
I found some used hardware to secure the rotors to the spindle (one set shown)
But decided to order new since I only had one special washer
I’m in a quandary about the well used and dented dust covers. Do I use the used and hide them with the wheel or bite the bullet for new ones?
Now it’s time to clean and paint the conterlink
Add the NOS idler arm to the K Frame
and add the NOS pitman arm to the steering box
The tie the two together with the centerlink
Next will be add the solid tie rod sleeves and NOS 11/16ths toe rods. Leave them in their natural finish or paint black?
I would go black. Such a great restoration demands black front end components.
Installed each rotor and then caliper with new pads and bleeder at the top. I’m surprised that the caliper holddown packet had 12 mm bolts where the bolt holes on the caliper adapters was 5/16th NC. I will get to Lowes in a day or two for some Stainless Steel bolts and washers of the correct length
I need to raise this side (passenger side) so it won’t slide on the floor.
Nice work Don :thumbsup:
On my ’65, I mounted the rotors to the rear and had a problem with them hitting and preventing full steering travel. Luckily, I didn’t tighten everything so was easily changed back.
Thanks for replying. I am curious as what/where were the calipers hitting
To prevent the wheels from full steering travel.
I searched all my pics and unfortunately wasn’t able to find any. Apparently when I test fitted and found the interference, I swapped back to the correct locations. All done without taking time to document with pics or notes. Sorry I wasn't more helpful.
But I recommend you test fit for yourself and make your own determination. Possibly yours could have something different than mine.
Before I did my conversion there were posts on various sites describing how easy it was to move the calipers to the rear. I didn’t get around to it for quite a few years, so did more research when I was ready for the conversion. There was nothing found about any interference with the relocation.
I was just thinking - were you using - the 65-72 4 piston Kelsey Hayes or the 74-76 single piston like I’m using?
I have the single piston like yours and swapped the spindles side-side. I don’t remember how much travel was limited, so if there was only a small amount then there might be a geometry difference between mine and yours.
My gauge cluster is a custom set of Dakota Digital gauges housed within a 66 Barracuda instrument bezel.
With the Dakota Digital system, up to an additional 16 specialty gauges can be displayed in the main menu cluster without having to resort to underdash or A pillar pods. I decided to add separate engine and transmission temperature readouts. It’s as simple as adding a 1/8 NPT bung to the oil and/or transmission pans (which I welded in place), add the sensor snd run the cable to the the temperature modules. I’ll add the cables just prior to lifting the engine, transmission and K Frame in place.
Knowing that my outer wheel bearings on my brand new front end brakes would be protected by one of these crappy looking, dented caps,
i couldn’t stand it anymore and bit the bullet and bought new ones.
