Nice score !!!
What state was it in ?
Believe they are same as front blinkers also / Kinda like Rambler Americans shared several items on many models.Call me crazy, but the reverse lights and housings look identical to the 67 Barracuda.
My understanding is gauge faces are aluminum, is this true?
Are the white knobs just plastic?
Horn ring appears to be broken.
My guess is the remote speaker control under the dash is aftermarket.
I was thinking that. Also thinking they are not easy to find.The radio knobs should match them; those chrome ones don't belong.
No, not the inner fenders or hood line.
It's just a 60 or 61 has a different K frame and steering box.
Lower control arms and steering linkage is different.
I meant the whole 60-62 A Body is the smallest engine compartment.
You can bolt a 62 k frame into a 60-61.
Column is different. Not sure about the firewall around the column.
60-61 don't have the common firewall wire disconnect.
ACC. GRP. #7 | 327 | BASIC GROUP (All models) heater, back-up lights, windshield washer, variable speed windshield wipers, outside left mirror |
TRANSMISSION | 343 | |
POWER STEERING | 351 | POWER STEERING** |
TINTED GLASS | 432 | GLASS, TINTED SAFETY, windshield only |
BUMPER GUARDS | 443 | BUMPER GUARDS, front and rear |
MIRRORS - GL. PROOF | 492 | MIRROR, DAY/NITE, INSIDE REAR VIEW |
ENGINES | 502 | ENGINE (225 cu. in., aluminum) |
AXLE RATIO | 532 | |
TIRES | 541 552 | TIRES 6:50 x 13 WHITE SIDE-WALL**, (set of 5) |
UNDERCOATING | 611 | UNDERCOATING |
N.C.S. - SOLD - FINISH | 652 |
P | D | Blue Roof & Body Paint |
N | D | |
T | 1 | Mono Tone Paint Style = the 1 In the STYLE OR CONV. TOP section of the BS |
D | D = Upper Door Frame or Moulding Insert Paint | |
Either way, it is the same as the primary Mono Tone paint color of D | ||
Plus, 284 (most likely a 4 would be on the BS) is VALIANT COLOR SWEEP, VALIANT 200 ONLY, is that V-200 and Signet 200? |
