340sFastback
V8 parts? I thought /6 was going in there?l the factory V8 parts are blasted ready for black epoxy.
408 in A100 with that drop dead beautiful body work paint? Wow!! Truck will be awesome beyond awesome, wow!!Long story. Blueprint was giving a good deal at Barrett Jackson so I ordered a 408. I have another Home for the hot rotted slant with the six pack of Webers.
frame connectors so you don't crack paint/wrinkle sheet metal with all the torque?
looked in the FSM and one drawing in lubrication makes it look like it's a "full unibody" frame. Is that so?
Post #502 shows frame rails run front to back. So while unibody its like factory frame connectors.frame connectors so you don't crack paint/wrinkle sheet metal with all the torque?
With a 408 it will appeal to a far broader number of buyers and value should be quite a bit higher then /6. Next buyer be like needs a sure grip who cares I want that truck....If it were going to be mine it would have the slant. I want to sell it and it will bring way more to a larger audience with the 408.
I'd like to go for a ride in that!!!!I doubt a 408 will hurt it. Might undercoat the rear bed bottoms with burnt rubber is all....lol. My buddy built a black A100 pickup with a 470 low deck stroker that was moved back 8 inches. Yeah, he extended the doghouse into the bed a little! Had a regular 727 in it, and the driveshaft was not much longer than a spray bomb can! It had a 3.91 SG and would pull the front wheels and carry them 15 or 20 feet. Not a wrinkle in the body or paint anywhere.
First time I rode in it, you couldn't have driven a finishing nail up my butt with a 10lb. sledge hammer!I'd like to go for a ride in that!!!!
Whens that 408 coming?
Nice! you have a workbench to work on...mine are filled with stuff. I have found tailgates are pretty handy, when the weather is nice.
For the steering box, the Jeep Cherokee version has successfully been adapted to older A/B Body applications. If you're not a stickler for originality, maybe look there.
You gonna run headers with that 408?
