First off-I cannot read the Vin stamped on the block. Pictures included, could not see the vin on the pan rail.
340 engine for sale.
Runs good, compression 125-140. Oil pressure 70 cold, 25 hot.
I can send a video of it running if your serious. If you are local, you can see it running. I will ship on buyer’s dime.
Specs
73 340 Block
Forged crank
.30 over with TRW 2316 Pistons
ARP rod bolts
ARP head studs
ARP main studs
Windage tray
Double roller timing chain, looking for receipt on brand.
Fel-Pro 521hd head gaskets
SFI Harmonic Balancer
Moroso Valve Covers, stamped steel.
Stock size oil pan, Milidon I think
587 Heads-
Shafts have banana groves for oiling.
After market shaft hold downs,
Cam- hydraulic flat tappet Hughes, 236-242 duration, .546/.563 lift.
Hughes 5003 lifters
Hughes valve springs- 1102E
Crane iron rocker arms, 1.5 ratio.
Summit pushrods
Also included with sale
Aluminum water pump passanger side exitand timing chain cover included.
Carter mechanical fuel pump.
Square back alternator
Aluminum radiator and hoses. no leaks.
Derale Steel fan
Asking 3350obo
Also willing to sell Edelbrock air gap manifold, electronic ignition TTI coated shorty headers, aluminum pullies as a package if interested. Not selling individual parts. Please don’t ask.
Going in a different direction with car.
Specs
73 340 Block
Forged crank
ARP rod bolts
ARP head studs
ARP main studs
Windage tray
587 Heads-
Hughes 5003 lifters
Summit pushrods
Derale Steel fan
Asking 3350obo
