[SOLD] 1976 dart sport part out
skep419
5.9 Magnum 4 speed afficionado
Minesoooota
located in Clarkfield MN
Car is very rusty and full of mouse piss.
I’m keeping the k frame assembly.
Passenger door was stuck. Pry bar marks on the inside and all the latch assembly and rods are jacked. Drivers side is good. $150 for both.
Wheels are BBP 14 and look to be 5.5 wide $25 each
engine wiring harness $100
dash assembly $150
fenders $150 each
beak $75
steering column $50
I’ll post most pictures
Let me know what you need and I can take better photos.
I'm a 67-69 dart guy so no idea what this stuff goes for. shooting from the hip. make an offer.
How much for the antenna? I would be interested in the license plate light if you haven't sold it.
Got it down to the bones. How many hours did that take to accomplish?
Rear bumper was full of gravel. Cut off wheel and air chisel to get the bolts out. Half of them broke. Not sure if any of it is salvageable.
Few weekends. 20-30 hours
Nothing came apart easy and I tried to take everything apart nice.
1 full can of PB blaster
3 cans of brake clean killing wasps
1 flex head harbor freight 3/8 ratchet
(Busted it on an upper control arm bolt)
a got a 74 i not sure but is their a ground wire on the bottom of the dash near the instrument cluster i need that screw and the 2 brackets that hold the blinker and the 4 way blinker
not sure what you need. Let me know if it’s in the pictures
what i want is where i put the red circle the screw and bracket i put an arrow at the key in buzzer would like to know were is it connected to also the blinker is under the cig ligher dose it have a bracket
can you drill or chisel or the bracket the holds the key in buzzer and the seat belt INTERLOCK MODULE i circled a picture of it
How are the inner fenders? I need patch panels from the center of the shock tower back to the fire wall.
