6-way seat track for A body?
carfreak6970
Pittsburgh
Hello everyone,
So as I am suppose to be getting ready for work my mind went down yet another rabbit hole:
I may have access to getting a reproduction 69 b body 6-way manual seat track and was wondering if it would not only bolt up to a 67 dart bucket seat, but if it would bolt to the floor with no modifications?
Thanks!
It’s possible it might be a direct bolt-in or with drilling a strategic hole (or a longer floor bolt) work. I am adding a 68 Power rack out of a 68 C Body wagon to my 65 Dart. Other than one mounting floor bolt being too short, it bolted right in where the original holes were for the bench seat. If you go with the 6 way, post pics on how The install goes.
EDIT: i should have stated the power rack was virtually a direct bolt in to the outer bench seat mounting hokes and INNER bucket seat holes.
So I found this:
Bucket seat tracks
68-69 seat frames between A and B are the same. So there is a possibility the 6-way could bolt up to the seat frame. However that same post says that the seat tracks are different between A & B, but doesnt say what is different...
So there is a shot. Ill have to get the seat track by the car and see.
