7&1/4 vs 8&3/4 OAL. both BBP
Rapid Robert
Lincoln Nebraska
have a 7&1/4 in a 73 dart & the mag wheels/tires are very close to the outer fender. I would like to swap to an 8&3/4. Are these pretty much the same total width? thank you for your time. RR
Since the 8 3/4 never came in the big bolt pattern in an A body, it's probably not an A body rear end, unless someone redrilled the axles and drums. You'll need to measure to confirm.
