A833 driveshaft length?
Muswagon
Winnipeg
I am going from 440/727 to 440/A833. I know the driveshaft will be too short, what is the needed?
1971 Duster, 8 3/4 rearend.
I searched but now I am dizzy as people seem to measure differently.
I have read anywhere from 47.75 to 48.96 "
My info says 48.96" cj-cj. I would measure as a double check. With the suspension loaded, bottom out the yoke in the trans....measurement (A) center joint to center joint. Then subtract 0.75-1.00".
From the 1971 FSM.......
Since the Duster never came with a 440, I took the differences and compared them from the same swap, but using 340 as a baseline......
It looks like the 833 shaft needs to be 3.97 inches longer than the 727 shaft......Assuming the shaft that you are using now is adequate for the 440/727 combo.
I have a 440, 833 8.75 combo and my driveshaft is 49.5" u joint center to ujoint center.
I wouldn't go off of someone else's measurements though. I would measure your application to get the exact length you need.
Mine is 45 on the nose which is weird. Local guy has a 48.8 out of his dart, new u joints and has the 727 yoke on it for $100… that’s a buy even if it’s not right but it should be just about perfect.
Cut the input shaft on the a833 after measuring 4 times. Keep in mind I’m a dummy so I cut a little less, but was too cautious. Too sketchy to do again right now as I’m rattled lol…. It sure you guys do the trans with a car on Jack stands, I used a trans Jack to check the measurement and I still had some warm pee running down my leg..
There's this chart that might help from MP..................
Is that a Lakewood bellhousing? If so, I wouldn't use it unless you are planning on hydraulic clutch linkage...even then there are some issues that need addressed.
I’m using a hydraulic bearing. Grabbed some 3/8 bolts to replace the stock 7/16 for the bottom holes. The alignment ring is good. Hopefully I’m not missing anything else with this bell? I bought it 3 years ago before I knew it was a pos, had this swap planned for awhile
Another stupid question while i am here.....
Things are very tight lifting the trans in while guiding it, can i install the shifter and rods easy enough with trans bolted in? Or is this easier to do before trans install?
I don't want more s*&^ in the way if I can avoid.
Make sure you check the bore runout. Use the smaller 130 tooth flywheel even though it can be used with either.
