Anyone here own an ‘08-10 Mopar car and willing to help me with some config files?
DionR
Spokane, WA
Looking for some help from someone that owns an ‘08-10 Charger/Challenger/300/Magnum and an OBD2 scanner. I would really like files from an SRT but would take anything right now. Looking for config files from the ABS module and the BCM module.
If you have a scanner already, the only other thing required is a copy of AlfaOBD. There is a free version so it wouldn’t cost any money and the free version can’t make changes if that is a concern.
Anyone capable and willing to lend me a hand?
If I understand things correctly, the BCM comes preprogrammed for every mopar build that year, and alphaOBD just let's you switch things on or off ?
So I would expect the files you need to be present...unless you somehow deleted them
Sorry, I should have been clearer. I don’t own one of the cars in question, or I would just go read it myself. :)
I went so far as to see if I can find one locally for sale but there isn’t anything with in 4 hours so far. And I have asked on the late model forums for help as well, but so far just crickets.
And the file isn’t present or missing, AlfaOBD does a read of the config settings and compiles a text file of how they are set. And then the full version of AlfaOBD can indeed set some things and turn stuff on or off. I have reads from my 2015 R/T and used AlfaOBD to turn on the full STP suite after swapping in a 8.4 screen, but that car had a different generation of ABS and doesn’t help.
My reason for the request is because I’ve gotten fixated on a “what-if” idea of retrofitting ABS. I was planning to use the LX/LC ABS module to feed the PCM a native speed signal on my G3 swap so the OEM cruise control could be made to function. Then I tripped over the idea that people are retrofitting ABS in cars using the MK60 E46 BMW system and discovered that the late model Mopars are using the same ABS module manufacturer, but a different model (MK25e). My thought was, maybe the config reads would give me some clues as to whether a retrofit would even work. And if I could get a read from an SRT, maybe I could update the pedestrian ABS module I have to be able to add the 3 mode ABS they came with.
And before you ask, no I don’t think the ABS from a 4200# Challenger will be as good as a system from a 3200# M3. But right now it’s just an idea.
Gotcha...sorta
Wish I could help, but I just got a '15 charger
(It did replace an 08 charger, but that car is long gone)
I have a 2010 Challenger R/T and AlfaOBD. I think the reason no one will share their config files is because they are specific to EACH vehicle. Using different files is asking for problems unless you inspect/change EACH line item comparing it to yours. I recently upgraded the BCM in my Gen 4 2500 Diesel and it took me weeks to review everything and make all the changes. I basically made two side by side speadsheets in EXCEL.
I'm not planning on building up a BCM or ABS using someone else's files. I simply want to look at what settings are available.
As an example, here is what I have from the ABS in my old R/T:
Vehicle Configuration Data: 2WD Rear
ECU Qualification:
ESC: Present
Brake Pedal Sensor: Present
CAN BLS: Not present
HW BRK: Not present
PN-2011: Present
ACC: Present
Pro Active: Not present
Feature PIN: Not present
HBC: Present
3 Channel System: Not present
HSA: Present
Long Accel: Present
Conti: Present
No Drive Test: Present
Evac and Fill: Not present
Intialization Status:
Initialization Complete: Passed
Drive Test Complete: Passed
Rolls Complete: Passed
Sensor Calibration Complete: Passed
Wheel Information:
Rotation Direction Left Front: Signal not valid
Rotation Direction Right Front: Signal not valid
Rotation Direction Left Rear: Signal not valid
Rotation Direction Right Rear: Signal not valid
Air Gap Left Front: Signal not valid
Air Gap Right Front: Signal not valid
Air Gap Left Rear: Signal not valid
Air Gap Right Rear: Signal not valid
Brake pedal status: Released
Analog Data:
Longitudinal Acceleration: Valid
Lateral acceleration: Valid
Yaw rate signal: Valid
Steering angle sensor (SAS): Valid
Primary Circuit Pressure: Valid
Status Pressure Front: Invalid
Status Pressure Rear: Invalid
CAN Data:
Transmission selector lever setting: Signal not valid
Actual Gear: Signal not valid
Target Gear: Signal not valid
PCM Brake Switch: Released
Hill Descent Switch: Off
ESP-off switch: Off
Allow ESP torque request: No
Reverse gear engagged: No
Sensor Offset:
Longitudinal Acceleration: Invalid
Lateral acceleration: Invalid
Yaw rate signal: Invalid
Steering angle sensor (SAS): Invalid
Primary Circuit Pressure: Invalid
Pressure Left Front: Invalid
Pressure Left Rear: Invalid
__________________________
Note that there is a line "PCM Brake Switch: Released". This makes me think that the PCM is telling the ABS module that the brake pedal isn't being pushed and leads me to believe that as long as the PCM is hooked up so it knows that I wouldn't have to worry about how the ABS module knows it.
But this is from a 2105 Challenger with the next generation of ABS module. I just want to know what settings are available in the 2008-10 modules to see if I can work anything out. And the only reason I want the BCM read is because often times the BCM is the programming gateway for the other modules so I am curious to see what settings are there to see if it would influence how the ABS module is setup. As an example, the 2010 SRT8 cars had a 3 mode ESP. I guess some of the R/T's could have it too, but I think it was standard on the SRT8 cars. I am curious if there is a setting for the 3 mode ESP in the BCM, because it could be that by setting it to Yes and re-configuring the ABS, it can be turned on. But I am just guessing because I don't have anything at all to look at.
And if people are worried about their VIN, just delete the line and save the file.
@DA4AD it sounds like you have exactly what I need. I'm not going to do anything nefarious with it, nor do I have a car I am going to mess up using your info. So, would you be willing to do a read from the ABS and BCM and send the text files to me?
I did learn that the +14 and down cars don’t appear to have a BCM, looks like they used a TIPM instead. The wiring diagram I have has a heading of “Body Control Module” but labels the module as the TIPM in the actual diagram. Not sure if the TIPM has settings or not, or if it is just a smart PDC.
I have purchased an ABS module out of an ‘09 SRT so I should be able to get some info on my own now once it shows up and I dig out my OBD2 connector. And I plan to try and find a TIPM as well.
Really not sure what the big deal was, but it is what it is.
Just to clarify, a new BCM does not come preprogrammed. If you have to have it replaced they either read the settings and re-apply those settings to the new one or they build a configuration off the VIN and build sheet and apply those. The BCM might auto set some things depending on info from other modules present on the networks, but it wouldn’t work to just plug in a new one and fire up the car.
AlfaOBD can pretty much do the same thing, minus building a completely new configuration.
Well, been an adventure so far and far from over.
I was finally able to get connected to a JY TIPM I bought as well as a PCM, but no luck so far with the ABS. I suspect that because I am not hooking the 2 large power wires up, the circuit board isn't actually powered. There is a key-on wire that I hoped also powered the circuit board but guessing not.
I am also still failing to get the SCCM to work so I can sniff the CC codes from. So lot's of road blocks still.
I also finally got my Arduino board coded well enough to see individual messages on the CAN C network, now to figure out how to copy and paste them into an Excel spreadsheet so I can sort them.
If anyone care, here is the read from the TIPM I was ask for help with.
___________________________
Tested device: Central Gateway Module
___________________
2024/04/08 16:00:18.751
ECU Identification:
ECU Origin: DCX
Supplier: Yazaki
Diagnostic Variant: 06: CGW (TIPM8)
Variant ID: 06
Development/Production: Development
Gateway ECU: Yes
Hardware version: 0000
Software version: 170101
VIN - Original: 2C3CA3CV8AH216375
VIN - Current: 2C3CA3CV8AH216375
ECU Code Software Identification:
ECU Origin: DCS
Supplier: Bosch
Variant ID: 01
Hardware version: FF17
Software version: 010136
ECU Boot Software Identification:
ECU Origin: DCS
Supplier: Bosch
Variant ID: 01
Diagnostic Version: 81
Hardware version: FF04
Software version: 030236
ECU Part Number:
ECU Qualification:
Sense - Battery Temperature: Yes
Sense - Coolant Temperature: Yes
Sense - Rear Wiper Park: Yes
Sense - Wheel Speed: No
Sense - Hazard: Yes
Control - Radiator Fan 1: Yes
Control - Radiator Fan 2: Yes
Control - Adjustable Pedals: No
Control - Cabin Heater 1: No
Control - Cabin Heater 2: No
Control - Cabin Heater 3: No
Control - HVAir Conditioner Condenser Fan: No
Control - Fog Lamps (Front): Yes
Control - Fog Lamps (Rear): Yes
Control - Reverse Lamps (Pwr Brd): Yes
Control - Position Lamps: Yes
Control - Rear Wiper: Yes
Control - Trailer Tow (Hvy Duty): Yes
Control - Front Axle Disconnect: Yes
Control - Headlamp Leveling: Yes
Control - Headlamp Wash: Yes
Control - T-Case: Yes
Remote Start: Yes
Auto Headlamp: No
TIP Start: Present
Flipper Glass: Yes
Left Front Signal Mirror: Yes
Right Front Signal Mirror: Yes
Sense - Liftgate Ajar: Yes
Sense - Outside Handle: Yes
Left Sliding Door: Yes
Right Sliding Door: Yes
Heated Mirrors: Yes
Power Mirrors: Yes
Control - Sway Bar: Yes
Rear doors: No
Intrusion System: Yes
Rear HVAC: No
Sense - Hazard Switch: Yes
Sense - Brake Fluid Level: Yes
Sense - Transmission Feed Control: Yes
Sense - Rear Wiper Park: No
Sense - Coolant Level: No
Sense - Hood Ajar (Digital): No
Sense - Reverse Gear: No
Sense - Hood Ajar (Analog): No
Control - Front Fog Lamps: Yes
Control - Ignition RUN/ACC and SPAD: No
Control - Ignition RUN/ACC and PAD: Yes
Control - Adjustable Pedals: Yes
Control - Transmission Feed: Yes
Control - Headlamp Wash: No
Control - Rear Fog Lamps: No
Control - Diesel Cabin Heater 2: No
Control - Diesel Cabin Heater 1: No
Control - Ignition Run: Yes
Control - Rear I-Wipe: No
Control - Power Inverter: No
Control - Ignition Unlock/Run/Start: Yes
Feature-Tip Start: Yes
Feature-Remote Start: Yes
Remote Start: Yes
Auto Headlamp: No
TIP Start: Present
Flipper Glass: Yes
Manual Transmission: Yes
Heated Mirrors: Yes
Power Mirrors: Yes
Got the ABS read! Looks like the circuit board is powered through the main power wires and the key-on wire is only a signal wire. Hooked power to to the smaller of the 2 and was able to connect. But first I pulled the motor and valve assembly so it didn't pull too much power for my benchtop power supply, or try and cycle the pump and spray brake fluid everywhere.
One of the reasons I was trying to get a read was to try and figure out if the 3-mode ABS can be turned on for a "garden variety" model. There are a couple of settings that might be related, but I couldn't find anything in AlfaOBD to set them. So I am speculating that the ABS module needs to be factory programmed for the 3-mode ABS.
Now if I could just get the SCCM to wake up and talk on the network. Then I could start sniffing the CC messages and maybe be done with this part of the project.
Here is the info from the read. Wish we could attach files here like the late model forums allow.
Tested device: ABS TRW/Teves/Bosch
___________________
2024/04/21 18:14:18.861
DCX / MMC ECU Identification:
ECU Origin: DCX
Supplier: Teves
Variant ID: 08
Diagnostic Version: 00
Hardware version: 0701
Software version: 070001
ECU Part Number: 04779679AC
VIN - Original: 2B3KA43R58H153831
VIN - Current: 2B3KA43R58H153831
ECU Origin: DCS
Supplier: Bosch
Variant ID: 22
Diagnostic Version: 08
Hardware version: FF07
Software version: 000130
ECU Part Number:
ECU Origin: DCS
Supplier: Bosch
Variant ID: 22
Diagnostic Version: 03
Hardware version: 0008
ECU Part Number:
ECU Configuration:
ABS Only: No
TRW: No
ASR: No
BTCS: No
RWAL: No
Conti Teves: Yes
Bosch: No
ESP: Yes
ESP with Active Booster: No
Rear Differential Sensor: No
Brake Fluid Switch: No
Long Acceleration Sensor: No
BLS1 HW: No
BLS2 HW: No
PCM BLS: Yes
BLS2 Bus: No
TCS/ESP Switch H/W: No
RWAL with ETC: No
Trailer Sway Mitigation: No
Hill descent control: No
Adaptive Cruise Control Equipped: No
Hydraulic Boost Compensation: No
Analog Valves: No
Permanent Disable: No
ABS Only: No
TRW: No
ASR: No
BTCS: No
RWAL: No
Conti Teves: Yes
Bosch: No
ESP: Yes
BLS1 HW: No
BLS2 HW: No
PCM BLS: Yes
BLS2 Bus: No
RWAL with ETC: No
Analog Valves: No
Bussed Inputs from PCM:
PCM Brake Switch: On
Allow ESP torque request: Yes
Actual Gear: Neutral
Target Gear: Neutral
Hardwired Switch Input States:
Brake Switch (Hardwired): Released
Redundant Brake Switch Status: Released
TCS/ESP Switch: Open
Brake switch normally closed: Open
Brake switch normally open: Open
Brake Pedal Force Switch State: Not defined
Ignition Sense: Yes
Initialization:
Initialization Complete: Yes
SAS Initialization Complete: Yes
Drive Test Complete: Yes
Bussed Output - Brake Pedal/Stop Lamp:
Brake pedal status: On
Stop Lamps Suppression: No
Bussed Inputs:
TCS/ESP Switch: Not pressed
Brake Switch 2 (Redundant Bus Switch if Applicable: Signal Not Available
System status:
TCS/ESP Switch: Not set
Brake switch: Pressed
Brake Pressure Sensor State: Not pressed
Brake Pedal Force Switch State: Off
Pedal Travel Sensor State: Not pressed
In-Plant Status:
Rolls mode active status: Complete
Bussed Inputs - Vehicle Configuration:
Drive Configuration: 2WD Rear
Suspension Type: 1
Brake Type: 1
Brake Type Modifier: Not set
Evac and Fill: Completed
Emission Rolls Mode: Disabled
My wife stil has her 2010 300c srt8 in the shed. I should be able to use a snap on obd2 scanner to get a file if you still need one.
Thanks! I would love to get a read of the TIPM and ABS from an SRT8 to compare with what I have so far.
Here's what I was looking for in the TIPM:
____________________________________
Vehicle Config 1: Tip Start Present: Set
Vehicle Config 1: Diesel Regeneration Present: Not Set
Vehicle Config 1: Hybrid Electric Powertrain: Not Set
Vehicle Config 1: Cruise Feature Present: Set
Vehicle Config 1: ABS Present: Set
Vehicle Config 1: ASR Present: Set
Vehicle Config 1: ESP Present: Set
Vehicle Config 1: BAS Present: Set
Vehicle Config 1: Full Size Spare: Not Set
Vehicle Config 1: Remote Start Present: Set
Vehicle Config 1: Heated Seats Present: Set
Vehicle Config 1: Off-Road Capable: Not Set
Vehicle Config 1: Vehicle Line: LX - Chrysler 300/Magnum/Thema
Vehicle Config 1: Left/Right Hand Drive: Left Hand Drive
Vehicle Config 1: Model Year: 10
Vehicle Config 1: Body Style: 4-Door Sedan
Vehicle Config 1: Country Code: USA
Vehicle Config 1: Drive Configuration: 2WD Rear
Vehicle Config 1: Fuel Capacity: 68.00 Liters
Vehicle Config 1: Wheel Base: Not defined
Vehicle Config 1: Radio Market Select: North America
Vehicle Config 1: DVD Region Code: Region 1
Vehicle Config 1: Special Marketing Package: None
Vehicle Config 2: Tire Pressure System Present: Set
Vehicle Config 2: Compass Temp. Display Present: Set
Vehicle Config 2: RKE System Present: Set
Vehicle Config 2: SKIM System Present: Set
Vehicle Config 2: Automatic Temperature Control HVAC: Set
Vehicle Config 2: Remote Steering Wheel Switches: Set
Vehicle Config 2: Power Left Front Seat: Not Set
Vehicle Config 2: Power Right Front Seat: Not Set
Vehicle Config 2: Power Folding Mirror: Not Set
Vehicle Config 2: Heated Mirrors: Set
Vehicle Config 2: Flipper Glass Present: Not Set
Vehicle Config 2: Power Lift Gate Present: Not Set
Vehicle Config 2: Power Left Sliding Door Present: Not Set
Vehicle Config 2: Power Right Sliding Door Present: Not Set
Vehicle Config 2: Police Lighting Feature: Not Set
Vehicle Config 2: Switches are Dimmable: Not Set
Vehicle Config 2: Disable CD Eject: Not Set
Vehicle Config 2: Disable Display of Clock Radio: Set
Vehicle Config 2: Tilt and Telescopic Steering Control Column: Not Set
Vehicle Config 2: Mirrors Contain Signal Lamps: Not Set
Vehicle Config 2: Windows Perform Door Vent: Not Set
Vehicle Config 2: Windows Perform Convertible Vent: Not Set
Vehicle Config 2: Mirror Switch Attached to Door Module: Not Set
Vehicle Config 2: Navigation System Present: Set
Vehicle Config 2: Central Locking Configuration: No Central Locking
Vehicle Config 2: Door Lamp Configuration: Dimmable Courtesy Lamp
Vehicle Config 2: Window Express Feature Configuration: Front Only
Vehicle Config 2: Memory Switch Configuration: Not defined
Vehicle Config 2: Interior Vehicle Theft Alarm Configuration: VTA
Vehicle Config 2: Security Switch Type: No Knockout or Disarm
Vehicle Config 2: Cabin Equalization Curve Number: 24.00
Vehicle Config 2: Side Airbag(s) Present: Set
Vehicle Config 2: Pass Airbag Disable Switch Present: Not Set
Vehicle Config 2: TPM Premium: Not Set
Vehicle Config 2: Reverse Chime: Not Set
Vehicle Config 2: Smart Feature Present: Not Set
Vehicle Config 2: Two Fuel Sending Units: Not Set
Vehicle Config 2: Front Park Assist Present: Not Set
Vehicle Config 2: Rear Fog Lamps Present: Not Set
Vehicle Config 2: Compass Mounting Angle: 765.00 deg
Vehicle Config 2: Compass Mounting Orientation: Right Side Up
Vehicle Config 2: A/C Present: Not Set
Vehicle Config 2: Rear Camera Present: Not Set
Vehicle Config 2: UREA/SCR System Equipped: Not Set
Vehicle Config 3: Axle Ratio: 3.64
Vehicle Config 3: T-Case High Ratio: 0.00
Vehicle Config 3: T-Case Low Ratio: 0.00
Vehicle Config 3: Tire Circumference: 2208.00 mm
Vehicle Config 3: Front Tire Circumference (Alternate): 65535.00 mm
Vehicle Config 3: Brake Type: Type 1
Vehicle Config 3: Suspension Type: Type 1
Vehicle Config 3: Front Tone Wheel Teeth: 46.00
Vehicle Config 3: Rear Tone Wheel Teeth: 48.00
Vehicle Config 3: Maximum Vehicle Speed: 254.00 km/h
Vehicle Config 3: Brake Type Modifier: Not Set
Vehicle Config 3: NTG4 Radio Present: Set
Vehicle Config 3: UGDO Feature Present: Set
Vehicle Config 3: EVIC Reconfigurable Display Present: Set
Vehicle Config 3: Weight Sensing System Present: Not Set
Vehicle Config 3: Cargo Lamp Present: Not Set
Vehicle Config 3: Rain Sensor Present: Set
Vehicle Config 3: Rear Heated Seats: Not Set
Vehicle Config 3: Power Inverter Type: None
Vehicle Config 4: Vehicle Brand: Chrysler
Vehicle Config 4: Occupant Detection Sensor Present: Set
Vehicle Config 4: WIN Module Present on CAN-C: Present
Vehicle Config 4: Max Load Inflation Pressure Front Tire: 30.00 PSI
Vehicle Config 4: Light Load Inflation Pressure Front Tire: 30.00 PSI
Vehicle Config 4: Max Load Inflation Pressure Rear Tire: 30.00 PSI
Vehicle Config 4: Light Load Inflation Pressure Rear Tire: 30.00 PSI
Vehicle Config 4: A/C Type and I/O Drive: Not defined
Vehicle Config 4: Fuel Tank Type: Not defined
Vehicle Config 4: ANC Equalization Curve Number: 255.00
Vehicle Config 4: Rear LED Stop and Tail Lamps Present for RT: Present
Vehicle Config 4: Rear LED Stop, Tail and Turn Lamps Present for RT: Present
Loadshed: Level 1 Entrance Voltage: 25.50 V
Loadshed: Level 1 Entrance Time: 255.00 sec
Loadshed: Level 2 Entrance Time: 255.00 sec
Loadshed: Levels 1/2 Exit Voltage: 25.50 V
Loadshed: Levels 1/2 Exit Time: 255.00 sec
Loadshed: Level 3 Entrance Time: 255.00 sec
Loadshed: Level 4 Entrance Time: 255.00 sec
Loadshed: Levels 3/4 Exit Time: 255.00 sec
Wiper/Washer: Front Washer Wet Glass Delay: 2.55 sec
Wiper/Washer: Front Wiper High Low Delay: 2.55 sec
Wiper/Washer: Rain Sensitive HOWW Cycles: 255.00
Wiper/Washer: Rain Sensitive HOWW Period: 255.00 sec
Wiper/Washer: Rain Sensitive HOWW Off Delay: 255.00 sec
Configurable Inputs: Hazard Switch: Set
Configurable Inputs: Brake Fluid Level Sensor: Set
Configurable Inputs: Wheel Speed Sensor: Not Set
Configurable Inputs: Transmission Feed Control: Set
Configurable Inputs: Tcase Type: Not Present
Configurable Inputs: Input #1 (B20): Not Present
Configurable Inputs: Input #2 (B14): Not Present
Configurable Inputs: Input #3 (E12): Not Present
Configurable Inputs: Input #4 (B10): Not defined
Configurable Outputs: Front Fog Lamps: Set
Configurable Outputs: Ignition RUN/ACC and SPAD: Not Set
Configurable Outputs: Ignition RUN/ACC and PAD: Set
Configurable Outputs: Adjustable Pedals: Set
Configurable Outputs: Transmission Feed: Set
Configurable Outputs: Output #1 (C5): Not Present
Configurable Outputs: Output #2 (A14): Not Present
Configurable Outputs: Output #3 (C6): Not Present
Configurable Outputs: Output #4 (B25): Not Present
Configurable Outputs: Output #5 (A9): Ignition Run
Configurable Outputs: Output #6 (C13): Not Present
Configurable Outputs: Output #7 (E2): Not Present
Configurable Outputs: Output #8 (E1): Unlock/Run/Start
Reconfigurable Parameters: Quad Headlamps Enable: Set
Reconfigurable Parameters: HID Enable: Not Set
Reconfigurable Parameters: DRL Dropout Enabled: Not Set
Reconfigurable Parameters: Park Lamp Loadshed Enable: Set
Reconfigurable Parameters: Front Fog Lamp Dropout Enable: Set
Reconfigurable Parameters: Combined Rear Lighting Enable: Not Set
Reconfigurable Parameters: Auto Headlamp Enable: Set
Reconfigurable Parameters: One Touch Lane Change: Set
Reconfigurable Parameters: Exterior Light Loadshed Enable: Set
Reconfigurable Parameters: Front Wiper Park Enable: Set
Reconfigurable Parameters: Rear Wiper Park Enable: Not Set
Reconfigurable Parameters: Reversible Washer Pump Enable: Not Set
Reconfigurable Parameters: Right Low Beam Voltage Regulation: 13.0 V
Reconfigurable Parameters: Right High Beam Voltage Regulation: 13.0 V
Reconfigurable Parameters: Left Low Beam Voltage Regulation: 13.0 V
Reconfigurable Parameters: Left High Beam Voltage Regulation: 13.0 V
Reconfigurable Parameters: Left DRL Voltage Regulation: 6.00 V
Reconfigurable Parameters: Right DRL Voltage Regulation: 6.00 V
Reconfigurable Parameters: DRL Configuration: Not Present
Reconfigurable Parameters: DRL Lamp Location: Not Present
Cabin Network: AHBM Automatic High Beam: Set
Cabin Network: AMP Amplifier: Set
Cabin Network: CCN Instrument Cluster/Cabin Compartment: Set
Cabin Network: DDM Driver door module: Set
Cabin Network: VES3 Vehicle Entertainment 3rd Row: Not Set
Cabin Network: SDARV Satellite Video Receiver: Not Set
Cabin Network: EOM Electronic Overhead Module: Set
Cabin Network: HFM Hands Free Module: Not Set
Cabin Network: HSM Heated Seat Module: Set
Cabin Network: HVAC Heat Ventillation Air Conditioner: Set
Cabin Network: ITM Intrusion Module: Not Set
Cabin Network: LRSM Seat Module Left Rear: Set
Cabin Network: MSMD Memory Seat: Not Set
Cabin Network: PDM Passenger Door Module: Set
Cabin Network: PTS Parktronics: Not Set
Cabin Network: Radio: Set
Cabin Network: SCM Steering Column: Set
Cabin Network: HIDT High Intensity Discharge Translator: Not Set
Cabin Network: SUNR Sunroof: Set
Cabin Network: VES Vehicle Entertainment: Not Set
Cabin Network: DISP Front Display: Not Set
Cabin Network: NAV Navigation: Not Set
Cabin Network: PASS: Not Set
Cabin Network: PEM Passive Entry Module: Not Set
Cabin Network: TMM: Not Set
Cabin Network: PTIM Police/Taxi Interface Module: Not Set
P/T Chassis Network: ABS: Set
P/T Chassis Network: PCM Powertrain: Set
P/T Chassis Network: TCM Transmission: Not Set
P/T Chassis Network: ORC Occupant Restraint Module: Set
P/T Chassis Network: WCM Wireless Control: Set
P/T Chassis Network: FDCM Final Drive Control: Not Set
P/T Chassis Network: ESM Electronic Shift Module: Not Set
P/T Chassis Network: SCM (CAN-C) Steering Column: Set
P/T Chassis Network: DTCM Drive Train Control: Not Set
P/T Chassis Network: CORAX: Not Set
P/T Chassis Network: OCM Occupant Classification Module: Not Set
P/T Chassis Network: ACC Adaptive Cruise Control: Not Set
I find it interesting that the tire circumference and tone wheel info (in Vehicle Config 3) is set here. Not surprised but interesting. I was hoping it was part of the ABS module and not in the TIPM.
It's also interesting that the front and rear tone ring settings aren't the same. And the tire circumference is about 46/48th's of what a 225/60R18 tire circumference should be.
No settings that I see that would influence the availability of a 3-mode ESP either. And the ABS module P/N number applies to all trim levels so betting the 3-mode ESP option is coming from the cluster. This is based on the fact that the ESP off button is wired directly to the cluster (Cab Compartment Node/CCN in Dodge-speak), so it makes some sense that the cluster could broadcast a message for "kind of off" or "actually off" for a 3-mode ESP and it is last place I can think of that could have the option enabled.
Based on what I have read about the ABS manufacturer, I am guessing that the module has a pre-programmed tone ring count and as long as the number of teeth front and back is the same the ABS functions fine. But if you had a situation where the number of teeth wasn't the same, it would probably require the TIPM to be part of the network to allow for adjusting it. But maybe the ABS module picks up the changes and just keeps the settings until the TIPM tells it something changes. In that case, maybe the TIPM could just be something to keep in the tool box and plug in if something needed to be changed or if the ABS module was replaced or something. All just speculation right now.
Could be important for me though as the hubs I might run have a 52 tooth tone ring and the 8.8 I expect to run has a 50 tooth count. Might not be enough to matter, but my guess is it would impact it and I either need to set it using the TIPM or get a custom tone ring for the 8.8 axles.
