[FOR SALE] Aux pulley for AC Small block
Syleng1
Karma is real and Life is short...
North Franklin, CT
This came off a 66 Barracuda 273.
Location is Southeastern CT.
I’m not sure if this is factory or aftermarket AC pulley for the crankshaft - bolts inside every small block Mopar lower crank pulley I own. There are 6 holes and one is on longed to fit both bolt patterns.
6-1/2” diameter.
3-1/2” tall
Belt v groove is 1/2” wide- single groove.
PN: D-132626 Inner hole 2-3/16” outer flange diameter 3-9/16”
Part was at one time sand blasted and painted black.
Asking $75.00 plus shipping.
I take Vendmo, CC by phone, check or cash.
Thanks!
Syleng1
So in my 1965 Barracuda 273, with power steering and non air, would this fit? I have an old used ac unit from Paul Carr and really want to get his a/c unit in my car for use.
You will need to mount the compressor, and check where the belt would be in alignment on the crank. Then get the dimensions of the pulley to see if it matches.
