Clutch disc diameter?
French demon
South of France
Hi guys
I would like to order a new clutch disc and I would like to know its diameter before removing the gearbox.
FSM tells 9 1/4 (standard) and 9 1/2 (optional) disc diameter for slant-6 and A230 transmission.
How can I know the correct one for my transmission?
:thankyou:
First we need year make and model - engine size and transmission size before we can help.
IDK what size clutch your 1971 Demon with a 198/A230 has,
but since the 198 is the smallest slanty available in '71,
I'd guess it has the smallest clutch;
But I'm just guessing, lol
Yes, it's logical :). But an optional 9 1/2" disc is mentioned in the FSM for the 198ci.
So, I suppose that it's impossible to determine the disc diameter without removing the transmission... :rolleyes:
Call Brewer Performance. They used to sell a scalloped 10" clutch to replace the 9 1/2" one,
.............So, I suppose that it's impossible to determine the disc diameter without removing the transmission... :rolleyes:
Not sure you can but maybe it's possible to get a measurement from the disc OD to the input shaft spline.
4" and less would be a 9" I believe.
or see if you can identify the trim/options
looks like you car could be "L" or "J" if yours is "J" whatever that means it at least had a 9 1/4 when it left the factory
if its an L and was a Europe assembled car we often got "special" equipment.. don't know why probably local environment or different servicing routine specified
look at barracudas many got high end trim and the formula S suspension and brakes i.e stuff optioned in just for export (CKD) Kit assembled or exported US assembled cars.
if in doubt get the 9 1/4 i doubt it will make much difference for this application and will work with both pressure plate
70.8 square inches of plate both sides vs 67.2 both sides
141.6 vs 134.4
6% reduction
Is your motor still producing 100% of the torque and power it made on day 1? 500-1000 miles after day one :) when it was run in.
Dave
141.6 vs 134.4
6% reduction
Dave
Hello Dave
"L" is for Dart, and "J" for Challenger.
And it's not an Europe made car. It has been assembled in Hamtramck, Michigan.
I also think that the 9 1/4" will fit... I saw that Rockauto has this kind of disc for sale.
Thanks all.
François
Hi guys
:thankyou:
Measure it Like Dave69 described or take it apart then order what you need.
I cannot take the transmission apart and wait for the delivery. I'm in Europe and deliveries from USA take at least one or two weeks.
Then you'll have to get crafty and measure it through the inspection cover. @Dan Brewer do you have any information for this member to help him out?
122 tooth wheels have 10.625" bolt pattern. You could measure from the edge of the disc to the CENTER of a pressure plate bolt.
If it has a 9.25" disc, measurement should be around 0.687". 9.5" disc = 0.562" 10.0" disc = 0.312"
I got some help from a friend here, and following his advice, I upgrade my clutch to 10"
I wasn't sure that my bellhousing and flywheel would accept it, but this friend has a '71 Barracuda with the same 198ci than mine and he has a 10" OD clutch.
I ordered this one from Rockauto :
More Information for M-PACT 05004
:thankyou: all for your help and your time
François
