Electric primer pump for fuel
toolmanmike
Moderator
Staff member
Office
I know I have read of a electric priming pump that you guys have used but I can't find the model or number. Help me out guys. this is a plunger type and I don't know how easily fuel from the mechanical pump would pull through. It should be rotary vane pump I think. Thanks
Universal Standard 5/16'' 90 L/h 4-7PSI 12V Electric Fuel Pump Self-priming US | eBay
need vane type pump. It will allow the mechanical pump to freely pull fuel through when not in use. Mr. Gasket sells a small simple one that is made for cars with carbs.
