Howard1784
What happens when you dyno an engine and it does not meet the advertised horsepower number?
Run it anyway. There's no way in HELL you'll ever match the same output from one dyno to another, and using different operators and even possibly corrected standards.What happens when you dyno an engine and it does not meet the advertised horsepower number?
What should happen?Yeah, was curious if one buys a BP engine advertised at 465 hp, but the motor dyno'd at 420, 430 etc..etc. what happens then, if anything?
Well in all seriousness, you think it could be off as much as 40 horsepower?What should happen?
I think they were known to set the timing conservatively and also at a lower RPM than what some of them Motors would actually roll out at on the higher end...What kinda Dyno's did Ma Mopar use? dat **** was Alway's Wrong! Lol
I can honestly say if I knew I was just kind of numbers I'd be upset by the way wasn't that damn Engine 5 grand a couple years ago? oh wait probably 10-15 years ago.. never mind I'm living in the past... when a dollar was worth somethingat 7250 buck for a 465 hp stroker thats 15.59 bucks er HP, if engine down 45 HP thats 701.16 thay shorted him, supposing proper tune and dyno accountability.....DWB
It should hold together if I ever send an engine for a dynamic test, someone shoot me, because I done went rapidWhat should happen?
They sent me a dyno sheet with mine in 2008.I thought blueprint engines gave you a print out of the dyno test with the engine???
Theoretical. It was really directed for Johnny Mac @ blueprint. For example, If I wanted to buy their 465 hp rated engine but the one they built comes in at 420, what, if anything happens?Did you actually receive an engine with lower than the specified power or is this just a theoretical question?
Rest assured all BluePrint engines fans, you know I would never let you down!!Theoretical. It was really directed for Johnny Mac @ blueprint. For example, If I wanted to buy their 465 hp rated engine but the one they built comes in at 420, what, if anything happens?
