Flasher female connector size
Mopar Momzee
Vacaville
Seems that some little pest ate some wires, can someone direct me to a link to purchase the connectors.
Standard 2 prong flasher, been the same since ??? 55?
If you need the packard inserts as well as the plastic connectors they clip into, I’d be tempted to search the for sale ads and look for a used wiring harness.
WTF, finally trying to be serious and I missed it entirely. Damn it
Need the connector (housing) as a well as the terminals. Maybe some wire too.
The metal terminals are usually Chrysler or Packard/Delphi 58 series quarter inch width. Get the ones that will crimp properly to the wire size.
Sources for Chrysler type wire terminals
The plastic housing of the connector is 90 degrees and common enough it might be at the repair connector store and similar places.
One from a junk yard could work as wel and less hassle to match upl.
I hear you ,but cant find you
You can probably go to your local Pick & Pull & find the connector for the flasher on one of the cars & splice it into your harness.
Here, I won't beat around the bush, Start a wanted thread here!
That connector and flasher are the same in millions of cars and trucks. The wire colors may be different. Parts yard will have it. Where its located in the various dashes makes it a hunt though.
And as I said earlier, you can actually buy these............from parts stores
I keep a bunch of the terminals on hand. The housings are USUALLY fine to reuse but not in your case. :) I usually salvage connectors off old harness I keep for that purpose.
Thanks to all that chimed in I got the info and ordered what’s needed. Hopefully I’m in business.
