dads71
Awesome! Looks sweet!That's the only shot I have with the OEM 1971 booster......
Here I am now....
Here I am now....
Wow. Really? I’ll post a pic of the kind that the engine builder sold me. See if it’s proper. I’m sure it will say zinc on it, if it’s the right one then. Thanks!When you change the oil you need to use oil with zinc. I think the the brand is classic car or hot rod oil. I will look in the garage and let you know for sure.
Ok. Thanks a lot. I will tell him that! He said that I can do it when I do the first oil change, but another person on here was saying that he doesn’t think the exhaust will even be able to be hooked up in the location it’s currently inShop needs to run the bolt out of the center of the 90 degree oil filter housing, pull housing off engine, then reinstall facing rear ward. I would order a new seal gasket kit cause builder may have skimmed RTV on gasket.
I believe the '71 340 pass side exhaust manifold had a center outlet which means good chance exhaust won't clear. And once exhaust pipe is on it will be much more difficult to re-orient that 90 degree adapter. My two cents its simply not acceptable having it installed completely wrong and should be corrected while exhaust pipe is off. And tell shop you are not a mechanic and need them to correct the issue. They should have flagged that issue PRIOR to dropping in the engine being you said they are a mopar shop have a bunch of Dusters laying around etc....Ok. Thanks a lot. I will tell him that! He said that I can do it when I do the first oil change, but another person on here was saying that he doesn’t think the exhaust will even be able to be hooked up in the location it’s currently in
Thank you for the message. Ya, I agree 100% with you. Crazy to me that an engine builder would install it on the wrong way, to fit a temporary shipping crate, so that it would later have to be switched around….possibly requiring a new gasket….and I’m assuming dumping a bunch of oil out of it, in the processI believe the '71 340 pass side exhaust manifold had a center outlet which means good chance exhaust won't clear. And once exhaust pipe is on it will be much more difficult to re-orient that 90 degree adapter. My two cents its simply not acceptable having it installed completely wrong and should be corrected while exhaust pipe is off. And tell shop you are not a mechanic and need them to correct the issue. They should have flagged that issue PRIOR to dropping in the engine being you said they are a mopar shop have a bunch of Dusters laying around etc....
Thanks! I can’t wait to have it home!!Great stuff! It will feel awesome having it in your hands again regardless how long the delays have been!
Thanks!Looking good
Thanks. I only need 1/4” spacers. I really like the look of a bit wider tires. I only went slightly wider, so I would avoid stressing the studs. Just can’t seem to find much info on spacers. I’ve found some universal ones that I may give a try!Beautiful color!
I'd drive it and check the tires frequently to see if they get chewed up. If they do, as long as the wheels aren't also very close to the spring, replace the tires with something 10-20 mm smaller. Using spacers may require new longer lug studs, and will of course push the tire closer to the quarter panel. Do you have lots of clearance to the quarter?
Definitely! Thanks1/4" will double your clearance, so that's good. Just be sure you have enough thread engagement on your lug nuts.
