carfreak6970
Hello Everyone...
So this past weekend I tried to install my master cylinder in a 67 Dart. The master cylinder is the 7/8 bore from a 75 Dart.
The push rod I had was an adjustable one from Mopar. However it was way to long!! the overall length at its shortest length was 7 5/8" long. With this installed it would have the brake pedal height of a couple inches under the dash board. Which means I would literally need to leap from the gas pedal to the height of the brake pedal, forget the heel toe downshift.
So I was wondering if anyone had a manual brake push rod they could sell me or have a shorter adjustable one?
Thank you
Thank you
