[FOR SALE] Mopar LA solid roller camshaft
darto
Petaluma Ca
LA small block solid roller cam custom made by Lunati.
Lift .636/.636
Duration 272/272 @ .050
LSA 104
Lash .025/.027
It is used, Removed 5/10/19 for a more street friendly cam.
Includes the bronze distributor gear.
Pictures show condition.
$260 shipped for cam and gear.
Do you know what the recommended install height is
Installed height of what?
The valve springs he is not listing?
This would be your choice on the valve spring to be used on your choice of head.
You can certainly use a 1.80 or 2.00 spring installed at that manufacturer recommended height on what ever head can use/accept that spring.
You already have the pertinent information above. Perhaps a call/e-mail to the manufacturer will yield good spring recommendation & results.
