need paint code for 68 dart GTS 383 engine
70duste
il
HI, I decided to pull my 68 GTS 383 engine and reseal all gaskets ,engine is turquoise
im looking for the paint code to repaint the engine to factory color specs
I plan on prepping block and heads then painting with epoxy primer and then spraying the correct engine color, so need a paint code for PPG or DUPONT,or any major paint supplier??
thanks
The paint in the spray can is blue in color and it shows on the cap. There was a change many years ago and it took me a while to find the color I needed for my 63 Dodge. I'm sure mixed paint will be different but don't trust the Mopar turquoise engine spray paint in the new cans.
