[SOLD] old nostalgia Milodon high volume oil pump
couper 340
maryland
I got a ED Hamburger oil pan and pick up for my engine and it had the Milodon 19050 high volume oil pump kit for small block the direct connection # was p3690852 this is a old nostalgia from back in the day . Took it apart the pump was in good shape body and cover had no wear the rotors had some small spot were something past through not bad . put a new spring kit in it and check specs clean and lube up will work good . will work on any LA small block use you standed pick up or if you have a big oil pan use the pick up for that pan . $65.00 with the shipping .
sorry here are pictures
