Post your diagrams and what not
And...............Service manuals. FACTORY service manuals...........
http://www.forabodiesonly.com/mopar/showthread.php?p=1970088617
This has been posted before, but two more showed up over at "MyMopar," that being the 67 cars. Don't thank me, none of this is mine. AbodyJoe hosted some, MyMopar some, and frankly I forgot who showed up with the 65 manual.
In the case of the MyMopar stuff, you must play with page numbers because the are consecutive in your viewer rather than the Mopar "dash" page numbering. This is pretty easy to figure out. I just type in a random page number, when looking for, let's say, chapter 9. I just keep typing page numbers up or down a hundred until I get close enough to "get into" the chapter, then diddle from there.
ABODYJOE page
http://www.abodyjoe.com/pictures/Misc.%20car%20info/
70-71 Mopar Parts
http://www.abodyjoe.com/pictures/Misc. car info/1970-71MoparParts.pdf
72 Service Manual
http://www.abodyjoe.com/pictures/Misc. car info/1972 Plymouth Chassis Serv Man.pdf
69 Dodge Serv. Manual
http://www.abodyjoe.com/pictures/Misc. car info/69 dodge service manual.pdf
70 Dart Challenger manual
http://www.abodyjoe.com/pictures/Misc. car info/70 Dart Challenger Serv Man1.pdf
71 Dodge Body Manual
http://www.abodyjoe.com/pictures/Misc. car info/71DodgeBodyManual.pdf
I don't remember who put this up but thanks!!
65 Plymouth Manual
https://www.dropbox.com/s/upks33txhbe9tjw/1965 Plymouth Service Manual.pdf
From MyMopar
66 Plymouth
http://www.mymopar.com/downloads/servicemanuals/1966_Plymouth_Service_Manual.zip
67 Dart Charger Coronet
http://www.mymopar.com/downloads/servicemanuals/1967_Dart_Coronet_Charger_Service_Manual.zip
67 Polara Monaco
http://www.mymopar.com/downloads/servicemanuals/1967_Polara_Monaco_Service_Manual.zip
70 Plymouth
http://www.mymopar.com/downloads/servicemanuals/1970_Plymouth_Service_Manual.zip
Vacuum gauge diagnosis chart:
Someone was looking for a breakdown, the other day. I found this today, and thought I'd share it. hope it helps.
Jon
'68 notchbck 440
:burnout:
I can´t remember from where I got these. But I thought I´d share them.
  • mopar_intake.pdf
  • mopar_exhaust.pdf
  • Mopar_carb.pdf
  • TRANSMISSION.pdf
Not mine. (To admin. Delete this post if its violates any rules.)
Author: Gary Lewallen (aka. Vaanth)
Date: 24 February 1998
Copyright 1998 Gary Lewallen
  • A Carter Thermo-Quad Guide.pdf
Rick sent this to me. I was in HTML and I had no idea what to do, so I just blew it up, and took a screenshot of it..............................so let's try it..................
Setting pinion angle. Get the trans output and pinion yoke parallel and roll pinion down whatever angle you are looking to set. If output shaft sticks out beyond seal, place angle finder there
1st picture shows the 4 different output shafts that were used in 727 car and light truck trans.
The 2nd picture (actually a PDF file you have to click on and open) shows air pressure test ports when rebuilding or diagnosing a non-lockup torqueflite (same on a 904)
I also have one showing the oil pressure diagnosis ports but it's too big to load. Have to run right now but when I get home I'll resize it and post it
  • Air Pressure test ports.pdf
I was asked to post this diagram for the exhaust cutouts on a 67-69 cuda. I can't take credit for it, as someone forwarded it to me. I can say that I used it to do my own cutouts and it is quite accurate.
1966 strut crossmember bushings...notice factory cup direction.
3/16" Brake line fittings
COLOR PART # DESCRIPTION
Violet 6026887 Master cylinder front
Blue 6026888 Master cylinder rear
Gray 6026436 Prop valve inlet
Red 6031764 Prop valve out
Blue 6029113 Std thread (long) at hoses
2208893 Brake hose retaining clip
3879283 Brake line coil cover (25 feet)
Some A body wheelbases
108" 1967-73 Valiant; 1967-69 Barracuda; 1970-76 Duster; 1971-72 Demon; 1973-76 Dart Sport
111" 1971-76 Scamp; 1974-76 Valiant; 1963-76 Dart (ex. Wagons);
