Power to manual steering shaft coupler
rumblefish360
I have escaped the EVIL Empire State!
Florida
Isn’t there an adapter coupler that makes up the distance when going from P/S to manual steering?
Who makes this part?
Did you know that the Double D steering shaft is made in two pieces, that slide together and, are riveted together with nylon rivets, to keep the bottom part from falling out when the column is not installed?
I bopped mine on a cement floor, sheared the pins, then stuck the thing back in the hole it came out of.
That was 1998.
But yes, there is an ugly adapter available.
Rick eherenburg has them for sale on his eBay store, ricks mopars.
Nope! Never had to mess with a column other than a turn signal switch and a simple removal. Thanks AJ
I bopped mine on a cement floor, sheared the pins, then stuck the thing back in the hole it came out off
OUCH!
The ones posted I’ll get. Thanks.
I have a couple of the Mopar Performance forged
American Made adapters sitting on the shelf if anyone
ever needs one.
Mancini sells them for around the hundred dollar mark, maybe a little more.
