Radio antenna
70Duster340
Cortland, Ohio
My Duster was purchased from the other owner with fiberglass fenders. It had an in-dash radio/cassette player which never worked. Knowing that the AAR Cuda and Challenger T/A came with fiberglass hoods and the antenna was relocated to the rear quarter panel, is this what I need to do to get a new radio to function? Or since the hood is metal, will the antenna work in the original location as long as it is properly grounded?
Thanks
An antenna does not need grounding to work. If you go the rear fender mount make sure the cord will reach. I imagine you'd need 10 feet or more.
Also, if you don't want to drill a hole in the car, they make no-hole antennas.
There's already a hole in the fender on the passenger side front from the antenna that the previous owner had installed.
So, why did they move the antenna to the rear passenger quarter panel on an AAR Cuda if grounding wasn't the issue. I understand that the fender was metal, but the hood was fiberglass. Got any info on that?
Nope, sorry. I know some on stereo and antennas, but you're on your own for Barracuda specific info.
Will try and remember to ask a friend that restores them, but the fenders were steel, only the hood was glass. My Dart has a fiberglass hood , just like many others, no radio problem. They didn't put the antenna on the rear of A- 12's either.
Well, this isn't necessarily Barracuda specific information I'm requesting. I'm just wondering why (according to the factory) that a fiberglass hood would cause a radio to not function properly. If they felt the need to move the antenna to the rear, it must have been causing a reception issue.
The antenna doesn't mount in the hood, so, why is that an issue? Am I missing something here? Fiberglass fenders are a different story. The earlier cars required the antenna to be grounded. Not sure on your year and model. Try running a temporary ground wire to the antenna housing to see if that helps.
From what I understand/remember, unlike a steel hood, fiberglass hoods don't shield the antenna from all of the RFI/EFI the ignition system puts out, so they had to move the antenna to the rear fender.
This isn't a Mopar specific thing, as both GM and Ford did this as was well on certain "one-off" models.
I have tried to research this. Apparently the fiberglass hood somehow created some sort of interference with the radio. Since my Duster has fiberglass fenders, and the radio didn't work when I bought the car, I want to be reasonably sure that the fiberglass fenders won't interfere with the radio I'm planning on installing.
I would think that you'd have issues with your antenna working well with fiberglass fenders. Antennas like a large, flat, smooth ground plane to operate at their peak. Fortunately for us, we're only receiving and not transmitting so you really don't need your antenna operating at its peak to be able to receive radio stations. Problem is that when your antenna is attached to a fiberglass fender, you're having it basically operate to its worst ability.
Where would you suggest I move it? The hood is metal, but the fenders are the fiberglass I'm concerned about.
I wouldn't move it if it were me. I'd rather come up with a different way to listen to music, like a hidden bluetooth receiver, than drill a large hole in a spot where it doesn't belong on one of these cars.
First try grounding the antenna. Run some temporary alligator clip leads from the antenna ground to various grounds on the body and see if your radio stations come in better. If they do, then you know you can just add a permanent ground wire as a work around for the fiberglass issue.
Thanks. I was intending to run a ground wire for the antenna. My concern was if the fender being fiberglass would somehow effect the radio reception.
