Reproduction 340-4 Speed Cam
krazykuda
How-To Section Editor
Orland Park, IL
krazykuda submitted a new Article:
For those of you that want to run a factory 68 340 4-speed cam...
I worked with another member here and we sent one of my cams that was custom ground to be a clone of the 68 340 4-speed cam to Ken Heard at Oregon Cams and they measured it so they can duplicate it and now have it available for...
Read more about this article here...
I am considering using this cam, anyone here installed this cam?
You may get more replies if you post your question in this thread...
I'm planning on having 2 cams reground by Ken. Never used a reground cam before. How do they hold up?
The base circle will be reduced so you may need longer prods....
Which is really a non issue if you build these like you should. Rocker geometry shouldn't be overlooked on anything, really. Good point my friend down under.
RRR,
Hope you & yours have a great Christmas & New Year.
