[Found!] Reverse Light 67 Dart
carfreak6970
Pittsburgh
Hello,
I am working on a 67 Dodge dart and noticed the sockets in my reverse light assemblies are toast.
Im sure finding 67 reverse light housings are either expensive or impossible to find (but if you have them, please let me know), but I am hoping to get replacement sockets. Mine are rotted through and the wires are burnt to a crisp due to the exhaust pipes.
is there someone that has these sockets? I did not try removing the rotted ones, but is this an off the shelf part?
thank you
The rim of the socket was crimped to the pot metal fixture. That is where the single contact bulb gets it chassis ground too. To whittle in a alternative socket should be something like this... Crown Automotive 3764863 Parking Light Bulb Socket Fits 84-97 Cherokee | eBay
It requires a different 2 contact bulb and the ground wire but it is at least similar, water tight like OEM.
