Revolutionary sight plug - almost no mess !!
'63GT
CA
I've been working on this a couple of months. New to FABO and the world !
Racers know, fuel level is crucial for optimal performance, and needs to be checked often!
Everyone (practically everyone) knows what this is:
...and you also know what a pain it can be to adjust your float level
It's messy and somewhat of a 'long-handed' process. You sometimes wish you could grow a third arm and hand, and you never drop the plug when you're in a hurry ! (wink wink)
Better have a rag ready, cause it's gonna get EVERYWHERE! Gas is hard on paint too. Not to mention, it stains ! And if you drop the plug, you're screaming for someone to shut off the pump or your engine, cause you're plugging the sight hole with your finger.
The clear sight plugs are cool, but far from permanent, and end up looking like this !:
Yellowed and in 2 pieces !
Do I smell gas ?! Not much of a return, at $16/pair..
The solution? EzSite™
length does not interfere with the float.
the EzSite™ plug always stays in, so there's never the risk of dropping it, or making the dreaded mess on that brand new manifold or paint job. It uses a Std Holley seal and it is Fast and Safe.
I sent a set to @yellow rose , and he was delighted with it's ease of use and simplicity.
"The design is brilliant. The work is beautiful. The concept is outstanding."
And when @yellow rose gave them a try...
"....and when you think about it, how hard should one jounce the fender to get the fuel to slosh out? That's pretty subjective. And who defines what a “trickle” is? Again, very subjective.
Your plugs eliminate all that crap. Where the notch is, the fuel is.
In the end, I can’t find a thing wrong with these. They look good on paper, they look great in your hand, and they work perfect in the field."
1 Turn plug out 3 turns
2 Rotate plug/indicator to desired level
3 Adjust float level - when fuel spills from hole, you're done !
4 Retighten plug
* Easy to confirm level (by simply loosening plug and turning out to expose the bleed hole. fuel will spill when hole is at fuel level.)
Your allen wrench stays in the plug, so there's no risk of it sliding down your fender and landing exactly in the middle of the car.
The days of scrambling around in the pits for a new seal and plug ARE OVER!
And unlike the clear plastic sight plugs (not intended for extended use), they're permanent!
Not only that, they're transferable to whatever carb you're using !
They're $20/pair, $30/6-Bbls(3) add $5 for shipping and PP fees
(multiples will be shipped for the same cost to single address)
PM me for orders
[FOR SALE] - Revolutionary New sight plug
(Special thanks to FABO member Terry for his expertise!)
BUT WAIT, THERE'S MORE !
Just Joking , that's a Great Idea , the older I get the harder it is to mess around with small screws and such.
Thanks for taking the time to come up with something usable! Dream it, do it...:usflag:
I take back everything I ever said about guys from Turlock!
(haha:D)!
Greg is always thinking! This is an idea that is long overdue.
I have spent way more than this on those plastic plugs in the past as they don’t last long, especially with race gas.
Nice job, sir!
Like changing metering rods in a AFB. Loosen the screw that holds the cover and move the cover out of the way. Leave the screw attached. Don't need to be dropping it down the carb.
...all while holding your breath !
Who says we can't multi-task ?!
Nice pal, just when you think you the Holley has completely evolved!
Everyone (practically everyone) knows what this is: View attachment 1715647830
View attachment 1715647839 Yellowed and in 2 pieces !
The solution? EzSite™View attachment 1715647840View attachment 1715647844 length does not interfere with the float.
View attachment 1715647842 the EzSite™ plug always stays in, so there's never the risk of dropping it, or making the dreaded mess on that brand new manifold or paint job. It uses a Std Holley seal and it is Fast and Safe.
4 Retighten plug
PM me for orders
What is the name of the company so I can send for them? Thanks
Are these plugs still available? I tried looking up Ez Site to no avail. I'd like to have at least 4 to put in my 4779 Holley carburetor.
Yeah, also looked up EzSite to no avail and inbox full on original forum provider ('63GT)
I have a bunch of them still.
Been too busy to keep up on fabo.. unfortunately.
I'll clear my in box so we can connect.
40 yrs of six pak tuning... base setting requires the fuel be at the bottom of the hole on the secondaries and dribbling out the hole on the primary....so how does this new product allow for this?
