Small Block Head Flow Chart
TurboGLH
CT
I'll add any flow numbers contributed by a member, but I don't want to take info from someone else's website if they haven't given permission. But no reason that people can't link like they have been, and use the info to compare to what we've compiled here.
h ttps://docs.google.com/spreadsheets/d/15SOi3ZNKQOGbLAcOgtiM_w6snBml-d5M0rKCrNZREpA/edit?usp=sharing
(remove space and copy/paste to view in it's own window
edelbrock CNC heads by Modern Cylinder Heads...in pdf file
  • eddy_flow_chart.pdf
RHS/Indy LAX head, 1.92/1.62 valves, @28”, 4.00” bore, no tube on ex, ootb:
Lift——in/ex
.100— 66/55
.200—118/104
.300—172/145
.400—217/167
.500—246/174
.600—253/176
IMM-prepped RHS heads from their website: http://www.immengines.com/indyimmironheads.html
Here is some numbers from some EQ heads that I bought through my local machine shop in Winnipeg. The owner let me come in on a Saturday and do some clean up on the bowls first and then do a bit of porting under his guidance. The valves are long stem LS Chevy 2.02/1.60 that they had on the shelf.
Basically the heads are similar to IMM EQs. I would like to buy a set of bare aluminum heads in the future and try a more in depth porting job.
Here are the flow numbers for my Stage II ported Edelbrocks, ported by Ryan Johnson at ShadyDell.
LIFT--IN/EX
.100"--63.0/NA
.200"--137.9/98.2
.300"--191.6/141.9
.400"--243.8/171.9
.450"--262.2/181.5
.500"--281.3/188.4
.550"--289.8/193.8
.600"--292.9/196.6
.650"--292.9/199.9
.700"--292.9/202.1
Bone stock 308 casting, no pipe on exh.
.100......54........45
.150......80........70
.200.....117.......87
.250.....150......108
.300.....164......126
.350.....183......139
.400.....195......150
.450.....205......159
.500.....207......162
CNC IndyBrocks out of box 2.055 1.6 valves, Indy's exh #s are without a pipe, mine are with a pipe
column 1 Indy's advertised #s
column 2 actual out of box #s
column 3 fixed valve job and better Ferrea valves
----------1----------------2--------------------3
.100 72/66..............59/49 ................ 65/49
.200 132/113 ......... 123/108 ............ 150/113
.300 197/145.......... 180/150 .............204/155
.400 248/170 ......... 229/178............. 248/184
.500 277/183 ......... 261/194 ............ 280/206
.600 302/191.......... 284/208 .............292/215
.700 306/197...........284/215............. 287/222
Stock RHS/Indy LAX head 1.94 intake/1.60 exhaust no tube......
.100 57/52
.200 124/105
.300 184/143
.400 230/163
.500 255/167
.600 257/167
Ported RHS/Indy LAX head 1.94 intake/1.625 exhaust w/1-3/4" tube......
.100 NA/NA
.200 144/131
.300 191/173
.400 234/201
.500 264/222
.600 280/236
.700 283/238
462 HP on a big bore 292ci/273
Ported RHS/Indy LAX head (8 cylinder avg.) 2.055 intake/1.625 exhaust w/1-3/4" tube......
.100 NA/NA
.200 145/124
.300 206/176
.400 253/214
.450 275/226
.500 290/236
.550 301/242
.600 303/248
.650 297/253
With these heads a 360/424 single 4-bbl stroker made 474 LB-FT @ 3,000 rpm, 574 LB-FT @ 5,100 rpm and 629 HP @ 6,400 rpm. Solid roller 258/260 @ .050, .660/.668 w/1.6 rockers, 110 LSA, 107 ICL and 91 octane pump gas from the Stinker Station.
SM CNC - Flowed by @PRH
Lift—- in/ex
.100— 64/49
.200—126/95
.300—166/132
.400—206/163
.500—242/179
.600—271/187
.700—284/190
Screws numbers aren’t really very viewable on my phone, so I tightened up the columns:
Lift——1——————2——————3
.100 72/66.........59/49 ..........65/49
.200 132/113....123/108.......150/113
.300 197/145....180/150.......204/155
.400 248/170....229/178.......248/184
.500 277/183....261/194.......280/206
.600 302/191....284/208.......292/215
.700 306/197....284/215.......287/222
SM CNC flowed by @PRH
Valve job, back cut valve and a blend.
Lift——int
.100— 67
.200—132
.300—191
.400—232
.500—262
.600—275
.700—281
Iron #974
11/32 nailhead w/undercut stem 1.94/1.60 valves blended in, minor guide trimming.
--------Int--------exh
.100..64.............
.200..128.....103
.300..191.....146
.400..229.....169
.500..241.5..180
.550..241.....192
.600..240......199
894 x head.
11/32 2.02/1.60 under cut stem valves
Ported. @28" 4" bore
----------int-----exh---
.100..68........
.200..131...110
.300..191...137
.400..238...152
.500..262...188
.550..266...190
.600..271...191
eddy head...2.055 intake 1.60 exhaust...
100 72/55
.200 148/108
.300 204/149
.400 247/181
.500 278/202
.550 285/207
.600 292/210
.650 290/211
SM 2.055 intake 1.60 exhaust
.100 74/56
.200 150/109
.300 205/150
.400 245/180
.500 272/200
.550 281/205
.600 290/209
.650 289/211
I wonder? Seems I’ve seen these blowing 340cfm
I haven’t blown any holes yet, so not there.
.100 74/56
.200 150/109
.300 205/150
.400 245/180
.500 272/200
.550 281/205
.600 290/209
.650 289/211
Did you do any chamber work to go along with those larger valves?
