I have for sale two used reversible screwdrivers with phillips and flat blade bits. One is a Husky #628-375 and includes 1-bit with a #1 phillips tip and a 3/16 in. slotted tip with the second bit having a #2 phillips tip and a 9/32 in. slotted tip. Without the bits installed there is a 1/4 in. and 5/16 in. nut drivers built into the shaft.
https://www.amazon.com/Husky-Reversible-screwdriver-Flat-Phillips/dp/B074LVPRCS?tag=fabo03-20
The second reversible screwdriver is an Allway 2000V shock proof piece #SD41 that includes 4 bits. 2 phillips and 2 flat blade reversible bits.
https://www.amazon.com/Allway-SD41-Composite-Shockproof-Screwdriver/dp/B000KKR0ZI?tag=fabo03-20
I would like to get $6.00 for the Husky screwdriver and $4.00 for the Allway screwdriver. Plus the shipping.
Ken
Edison, NJ
HUSKY
ALLWAY
Ken
Edison, NJ
HUSKY
ALLWAY
