70Duster340
Can someone please advise what the difference is between the two? The manual I have on CD doesn't show the difference. Also, is the wiper assembly different?
Thanks
Thanks
Correct.So then, how did the 3 speed wipers work? Was it actually a very slow swipe on the first setting, and increasing in speed with the next 2 levels?
YesSo what makes the variable speed and the 3 speed wipers is the switch? I have several switches, and the 3 speed motor.
Well, I was incorrect. I only have a 2 speed and a 3 speed switch.
Now another question. I have a Chrysler interchange book. The part number for the variable speed switch (apparently no 3 speed option that year) is not the same part number as the one I have. According to the interchange book, the switch I have is for a Challenger. It appears that the terminals are the same, so I can assume this switch will work?
That's a good piece of advice. Is there somewhere that I can find a wiring diagram that's color coded for a Challenger?
