skep419
5.9 Magnum 4 speed afficionado
Right or Wrong all answers welcome
It came from China...
Ding Ding Ding! We have a winner.Great Wall of China? I've heard the term China Wall used more than once...
Cali to middle american railroad tracks were laid by chinamen.
There is a very good doc series called hell on wheels about this
Not sure "doc" would be a propper description of the series.There is a very good doc series called hell on wheels about this
China rails are the aluminum fillers used on the front and rear of intakes to seal the lifter valley.
Great movie!Also documented in Blazing Saddles.
'Come on, boys! The way you're lollygaggin' around here with them picks and them shovels,...' - Blazing Saddles quote
lifter valley ends are referred to as the china wall, The fillers used to extend them were referred to as the china rails.I read the term in books with it referencing the long thin front and rear wall of the block ends. How it came to be for sure, IDK, it does bare a resemblance to the Great Wall of China. So I bridged the gap like that.
Older folks have “Chinaware” of referred to as simply “China” to eat on. Normally an Ornate and beautifully decorated plates that are fragile. On an engine block, the rear walls would be considered the weak spot of the block when handling/machining it.
Pressure is next to the distributor on the China rail, passenger side.
Oil temp is normally taken at the oil pan with the sensor in a hung ether welded on the pan by yourself or done at the factory on a high performance oil pan.
In a few books the term “China wall” was used and from what I remembered as what I wrote. I’ll check the books and re read.lifter valley ends are referred to as the china wall, The fillers used to extend them were referred to as the china rails.
Ummm, Oooooooo kay! I don’t know what you mean here and it’s weird.Here is a post from you in another thread. Richard, Your disagree was just a asshole shot. But I get it. I found the treasure. LOL
Roger that Sir. Key word for me is “Extensions.”The thread stated wrong or right welcome. My interpretation of the china rail is the extension of what is referred to for years as the china wall. China rails were just the extension added to the top of what is referred to as the china wall.
Wherever you bought a W5 top end the question that came up was, Were the China wall intake extensions included?
