Wiper hose location
70Duster340
Cortland, Ohio
Can anyone here maybe send me a good picture of how you routed the wiper hoses? My Duster was purchased from the previous owner without a washer reservoir, hoses, and nozzles. I have collected a new washer reservoir, nozzles, and an electric pump. Unfortunately, I can't find anything in the service manual that shows how to route the hoses.
Thanks
From pump motor to 1 to 2 splitter.
One leg goes to drivers squirter
The other goes to the pass side squirter.
There are 2 screws that have a hold down one is visible above the wiper motor the other is above the master cyl
I can get better photos of you need them.
This is a manual pump setup but most is the same if you have electric.
From green on reservoir up to cowl to green on the splitter
Blue and magenta along cowl to respective locations
Red X is the grommet through the firewall for manual
Thanks for all the responses, folks. Very much appreciated .
What size is the hose from the reservoir to the splitter? And from the splitter to each nozzle? I ask because the hose from the reservoir to the splitter appears larger than the ones from the splitter to the nozzles.
That's a very informative picture!
Thanks
Does anyone know what size the tubing is for the windshield washer, from the reservoir to the splitter, and from the splitter to the nozzles?
0.192 is the OD of the tube of on the pump.
0.141 OD for the pipe on the squirter
Note the R and L on the squirter
