Found this chart of how to hook up test meter. It seems most people are scared of them easy peasy hope it helps. Has most of the common hookups rpm, dwell, amps, volts and ohms. This is from Sun Corporation in the 70's. Great for use on points cars and electronic also. The tach hook up is also the same as dwell if it does not have a inductive pick up.
