Learn How to Solder Correctly. In this video I show you the tools, tips, tricks, and techniques to properly solder, from what type of solder and flux you should use to how to splice the wires together for a strong soldered joint. I show you how to strip the wires, add heat shrink, splice the wires, solder, and melt the heat shrink to make a perfect soldered connection!
Products Used:
Solder: http://amzn.to/2cfjNcv
Rosin Flux: http://amzn.to/2bVPzMB
Soldering Gun: http://amzn.to/2c0cCoe
Soldering Iron: http://amzn.to/2c0cRiX
Wire Strippers: http://amzn.to/2cDPvyk
Automatic Strippers: http://amzn.to/2c0cV27
Silicone Paste: http://amzn.to/2cEMikT
Helping Hands: http://amzn.to/2bVQL2E
Heat Shrink Kit: http://amzn.to/2cr3NmA
Butane Torch Tip: http://amzn.to/2c1QPzg
