ValiantS
Always impressed me!5.75 / 117
9.10 / 145 best so far…. Still 1200DA
just not enough mph to be one of the “cool kids”
Definitely! My buddy’s Chevelle has been 1.28 60’ and I’m gunning for him with 5.40s so I’ve got a long way to go for sure.bet you’d love my 1.24 60 as much as I’d love that 9mph
What are the details of the car? pics?
No room for turbos under the hood??What are the details of the car? pics?
5.75 / 117
I havent posted on here in a while. Car has gotten some upgrade. Went high 8s in the quarter and I think I posted those times. Car got an all aluminum big chevy for a season. Built that engine and it just went 8.8x at 152 in a 3700lb chevelle na.. pretty proud of that but I sold it and it helped me get into a hemi. When I ran it my car weighed 2640lbs and I was spraying 550 at the hit with an IS sledgehammer plate. It went 1.11 60ft.
So last season I put together a turbo hemi combo. 526 kb block, Dart fuel heads, Bryant crank, grp rods. Single set of injectors, methanol, twin 88s, s400 frame. Holley hp ecu and went 174mph in the 1/8 at 2940lbs.
ThanksSuper nice race car.
Love the cam card picture.
Now that’s helpin out!
Some still seem to do so.
These “How to” threads were put up in order to help out and it’s amazing how it’s like pulling teeth for simple information.
alright fella's here's the combo.
74 duster all steel except hood, front bumber,lexan windshield
never weighed or corner scaled. typical weight removal.
all qa1 front except k member,.810 torsion bars, used shocks, strange brakes front,
cal Tracs, split mono Leafs, adjustable shocks. 3.55 true Trac 275 mickey's drag radial
stock fuel tank,1/2 pickup-fuel line, old carter mechanical fuel pump,850 4150
904 good bands,clutches,turbo action reverse valve body and converter,2500 stahl.
steel driveshaf,1350 u joints, old school foot brake.
junk yard 5.9l block, cast crank, stock rods, all Arp studs-bolts. fully grooved bearings
0 deck forged pistons,kevco oil pan with baffles, Melling oil pump, no concrete,girdle,oiling mods. correct dampner,flex plate and balance for external balance Magnum. Mopar timing chain with tensioner
Edelbrock magnum heads cnc'd,comp cams rockers, Edelbrock push rods, comp cam hydraulic roller, m1 intake, cometic head gaskets.
nitrous express plate, stand-alone fuel tank and pump,nx delay timer, currently using 250 shot
this system has been flow tested and spot on.
ready to run msd dist., no 6al etc, Ron Francis wiring thru whole car. optima battery, alternator
nothing special, crazy cost, rare parts, or computer tuned. lots of testing,tuning,driving and hard work. I know some of the parts are questionable, but this combo has been going on 3 years. 9.88 @ 136 I think with better 60ft, E85 conversion maybe, or converter change 9.60's are doable. I didn't list everything or more tuning spec, set up's,etc but feel free to ask. not the fastest,but fast for what it is!!!!!! ill post some pics later
thanks,motorcity magnum
Seriously I need to go look at my notes from 3 years ago. When I first put this combo together I made about a dozen passes on motor. Ever since it’s all or nothing when I stage. Sounds weird but it worked for me. 11.50’s-11.70’s I think? Not sure on mph. Ill dig thru my notes tomorrow. Maybe time for motor only pass?..what will it run without nitrous.
