You bought a headlight kit with relays from Toyota, do you mind sharing a part number?There was a thread on here a while ago about sealed headlight kits with relays. I bought one from Toyota but it is still in the box.
@crackedback makes them, but Rob is recovering health wise.
Thank you, that’ll be my back up if Rob can’t make one when I’m ready.81110-60P70 is what I got. Bought direct from a Toyota dealership. 30+ bucks. Place was a brand new facility here by I-90 in Austinburg. Cleaner than some hospitals…wow.
This will work in a 69 Satellite, 70 and 72 Duster?
I am installing on my 72 duster , its a pretty simple conversion for headlights , I used these on a 79 f100 , works great ,, all are the same really from those years , you can google the wiring diagram for a basic setup on how relays are wired ,This will work in a 69 Satellite, 70 and 72 Duster?
That's correct as the drivers side is all that matters, the factory wiring is the same , ties in to drivers side and runs to passenger side , an it all ties thru floor dimmer switch as well for hi/lowI see one plug to power it. That plugs into the driver side stock light female socket, then the new plugs go to the new headlights and the stock passenger female socket is not used?
Do you mind sharing the price?I gave up on cracked back getting back on here and hit up @slantsixdan he has a guy that makes relay kits. They look real nice.
I actually never looked close at mine to see , if it does its minimalHow does this system affect the tail lights? Will they become brighter?
Mine was for a dual headlight, 150$ for the parts and wire or 210$ for him to make it up for you.Do you mind sharing the price?
They do have kits that make your taillights brighter. The headlight relay will only make your headlights brighter.How does this system affect the tail lights? Will they become brighter?
I made my own with a couple of $5 relays. Not very hard if your under hood wiring is in reasonable shape and not too brittle.
It's nice to see where you are going, and just as important, is to be seen by others coming up behind you. It looks simple enough to buy the relays and try it myself, but electrical work is challenge for me at times.They do have kits that make your taillights brighter. The headlight relay will only make your headlights brighter.
I have the Toyota headlights but mine didn’t come with any kits. I’m not real into electrical myself.It's nice to see where you are going, and just as important, is to be seen by others coming up behind you. It looks simple enough to buy the relays and try it myself, but electrical work is challenge for me at times.
I'm leaning towards the Toyota kit as it includes the headlights.
Only if there is a problem (resistance) with the power feed from the alternator to the main splice.How does this system affect the tail lights? Will they become brighter?
