I Chose the 383 Big Block
I bought 2 used 383s because that's what was available for dirt cheap.
Not disappointed at all.
Aluminum heads and a tunnel ram, enjoy.
This is the Big Block A Body Tech forum after all.
I love how people always cry about the weight of big blocks. There's only about 150 pounds difference between a 360 and a 440. The 383 has a 4.250 bore. Say that ten times. Maybe it'll sink in. If not, you need help.
People will go on endlessly over the cid and bore difference between a 318 and 340/360 but an extra 23-43 cid plus a 1/4" bore waste of time. Funny how no replacement for displacement/bore ends at 360/408.
If you don't mind a square engine you could be running around with 496 instead of 408.
I have a square engine in my truck. The Ford 400. A lot of people wrongly claim they are junk, but in reality they're one of Ford's best engines. What's not to love about a square tall deck 400 cube Cleveland? It's a torque monster.
Call Ken at Oregon Cams and tell him exactly what you're looking for. He will steer you right.
A strong second to this! Ken has ground me 3 different cams and each one has performed better than expectations in the engine they went in. Also, there isn't anything wrong with a 383. You do you. You're also in the right place to get quality advice if you can sift through the pontificators. Welcome to FABO.
Make that a third. Ken's ground a few for me and a few for a local friend. I cannot say enough good about him.
But there is nothing more beautiful as far as a big block tucked into and A body. Oh, how sweet it is.
If you had read my reply, I don’t think you’d be writing what you did. As to directly reply to your post, I agree.
For clarification purposes only. I have had a low deck B-400 in a ‘71 Duster w/a 727 & 4.88 gears. The car was gutted and a pair of basic race buckets installed. SS springs, 6 cylinder bars, manual steering & brakes, drums in all 4 corners.
Oh dude that was my opinion nothing meant to be offensive. I don’t think I said anything offensive.
FWIW, I didn’t take anything offensive.
We are good! NO worries no issues.
I once helped a friend install a 383 with 727 in a 69 dart. Fender well headers and engine plate. It was an experience. Had to set the rear up also get pinion angle and weld the perches.
Headers and torsion bars are a nightmare!
The 1st engine I put in my B'cuda(many years ago) was a 383 I literally threw together with parts laying around the shop and a 484 purple cam. I hoped it would stay together long enough to sell the car. I(obviously) never sold it. I beat that poor 383 ruthlessly for many years...it didn't make the most power but it also was no slouch for what it was...it ran fine until the day I pulled it....pretty good testament to those lowly 383s
Now a roller cammed,Eddy headed "little"400/470 lives there. appearance wise, not much different.....performance wise a LOT different! My little fish will never see a small block......big block a-bodies have a way of putting a big smile on your face!
What are your thoughts on salvaging this piston on my 383? The rings are sticking pretty bad, its the culprit on the engine seizing up. All the others look good.
My vote is to remove the piston & check the piston rings, piston skirt and cylinder wall on the right side where all the corrosion is located. I think you'll find there is a reason for the rings to be grabbing. I can't tell from the picture, but it appears the same corrosion is in the water passages at the top and bottom of the same side. Crack in the #1 cylinder wall? Time to tear it all down & evaluate what you have that is useable.
It's not salvageable. Period.
I agree w/RRR. That piston is done. I'm surprised the cylinder wall survived. If this were me, I'd pull the other 7 pistons. Next, I'd put a mic on the cylinder walls with an eye to a rehone or possibly new +.020 slugs.
I will change the pistons and the rings , connecting rod bearings and crank bearings and also do a home hone job on the cylinders put a new rear main seal in it and clean the pick up tube. Make sure it’s clean and clean the oil pump if you do not wish to buy a new one
