Brake Bleed?
Mcfarlrm
Florida
Replaced both calipers (18-4067 & 18-4068) and brake hoses (HSP5563OM). After cold start and car has been sitting for awhile, I have to pump the brake pedal a couple times to get the brakes to firm up. After that, everything is good. Assume I just need to bleed them again but curious if there might be another common issue someone can think of.
Bleed them all. Start at the furthest wheel from the master, then the next furthest and so on.
