A lot of times you never hear about it . But the coach can only do what higher ups tell him to do . Paul Maurice complained he couldn't do what he wanted when he was coach for Toronto.
Ownership matters...A lot of times you never hear about it . But the coach can only do what higher ups tell him to do . Paul Maurice coplained he couldn't do what he wanted when he was coach for Toronto.
Jets Coach gone as well. Toronto is one tuff town to coach in. No mercy.Toronto Maple Leaf Coach Just got fired.
I've used this under a lawn mower and the grass washes off easily...think I got it at Farm n Fleet.So, after I paint the chassis on the Charger, would I use Slip Plate or Fluid Film to help with the salt at Bonneville?
I need to get or build a lift for the mower to better clean the deck.[/URL]
I have a motorcycle, ATV one you can have it if will work........................similar to thisI need to get or build a lift for the mower to better clean the deck.
I just use the hose with the nozzle set on jet, mower running full throttle, squirt water where the engine meets the deck-cooling slots(?) and then aim it underneath front to back. usually get squirted once in awhile. need to clean it because when it sits in the garage and I go in there to putz around, the allergies kick into high gear.I need to get or build a lift for the mower to better clean the deck.
I back it up onto a hill next to the driveway to gain clearance... clean the underside with pressure washer and a plastic putty knife.I just use the hose with the nozzle set on jet, mower running full throttle, squirt water where the engine meets the deck-cooling slots(?) and then aim it underneath front to back. usually get squirted once in awhile. need to clean it because when it sits in the garage and I go in there to putz around, the allergies kick into high gear.
the motorcycle lift be good for a rider...mines just a push
Have never cleaned my deck... probably has Deck Cheese by now... .
I rarely even think about my Deck.. i have confidence in it.... and although it's only 38" i think it's enough...Having a clean Deck is important. Sometimes obsessing on how clean your deck is can be a sign of emotional issues.
You shouldn't have Deck envy.I rarely even think about my Deck.. i have confidence in it.... and although it's only 38" i think it's enough...
That deck definitely suffered from over use and neglect.Luckily i always took good care of my Deck.... no one wants this..
