1967 Barracuda 273 Fan Shroud Needed
mopardude62
Missouri
I have a 1967 Barracuda with a 273 and need to find an original fan shroud for it. It has a 22" radiator and a solid drive 7 blade 18" fan.
I have another fan shroud I picked up at a junkyard off a 1971 Dart thinking it might fit. It comes close but hits the top of the shroud. The opening is 19" across and my fan is 18" so there is the perfect amount of clearance but the fan isn't "centered" in the shroud hole. I think I'd be better off just trying to find the one that fits.
Please let me know if you can help. I have attached a couple of pictures of the shroud I have.
Is it an a/c car? My 67 valiant has a clutch fan but is also an a/c car. I can get the # off of my shroud if you need a part #
A better question is,
Can anyone testify that a recently produced reproduction 614 shroud will not melt into the fan ?
We all know the early repops did melt and they may never escape that reputation.
Part number for the slant 6 shroud is 2582 037 45511
It will work with a V8. Install it upside down.
Hope this helps
