[FOR SALE] 1970 plymouth duster with big block & dana 60
#MadMax
Rating - 0%
0   0   0
I have a 1970 plymouth duster. The duster is a turn key car get in and go today. This is a street car. Has title in my name. The duster has a Professionally welded in 8 point cage. Also has frame rail connectors. I just put in a new seat belt in February. Has all new door seals and window seals and new front windshield with new seal as well. New cat whiskers.
The engine is a new rebuilt 400 big block pump gas engine. The block is 530 RV block all stock all new seal power bearings and rings has a edelbrock performer dual plane intake and a general kinetics 512 cam Complete MSD Ignition system.
The 727 HD with tci 2800 stall convert. B&M quick shifter.
The drive shaft has drive shaft loop.
The suspension is upper QA1 control arms and drilled and sloted front disc brakes and super stock rear springs.
The rear-end is a dana 60 410 gear and new dura grip Yukon center section and 11" drum brakes. All redone this pasted winter.
New 15 tires and rims are mopar steely 15x5.5 all 4
Location is Collins ohio 44826
The price is $24,000.....O.B.O
